Question about Gateway (5500381) CD-ROM Drive
I can not pull up my cd/dvd drive, it is gone of my computer.
  • 721 Answers
Not knowing the model or operating system you have,I'll assume it's xp. Right click "my computer" & hit manage from the drop down box. Now hit "disk management", it should be seen in the lower window. If not,it may be a bad drive. The last thing to check is under BIOS setup. Re-boot & press f1 or whatever key it says during post to access it. The drive should show up under IDE devices, if not it's definately bad.
Posted on May 04, 2010
Hi my computer doesn't see dvd/cd drives .When i pull it up in device manager it shows drives but they have a yellow exclamation point in front of drives what can i do . thanks hotrize
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | Microsoft Windows XP Professional
Dvd burner for windows has gone
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 29, 2011 | Dell (7W036) DVD+RW Burner
Cannot get the door open to put in a dvd disk.
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 20, 2011 | CyberLink SW- DVD Software Power DVD...
My dell studio 1737 doesnt read any disk when i put them in
HI Friend, In this case I would recommend you to check if the CD/ DVD drive is getting detected in Windows Explorer or not ( MY computer) window. If it is not getting detected there then goto device manager and check if you have yellow bang on the CD/DVD drive option or not. If there is a yellow bang then you need to follow the below steps:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation anderror code on the CD or DVD drive is gone
### If CD/1) Close all open programs 2) Click on Start, Run, and type REGEDIT and press Enter
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
### IF CD/DVD is getting detected in windows explorer then try updating the firmware for CD/DVD drive
Dec 14, 2010 | Dell Studio 1737 Laptop
I have a Gigaware Hard Drive enclosure, When I plug it in to my computer it showes up in the device mananger but I am not able to access it as a drive to get the information off of it. I had it pluged in...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 06, 2010 | Computers & Internet
MY COMPUTER IS NOT SHOWING THE CD DRIVER. HOW CAN I EXPLORE THE FILES OF MY CD?
you might have to physically unplug then plug back in this should activate the found new harware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 05, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My dvd drive reads all cds but not dvds
It's a two part laser ( cd / dvd) the dvd portion has gone out. You can try cleaning the lens but usually the drive needs to be replaced to correct the problem.
You could also try flashing the drive's firmware.
What model is your computer?
Jan 20, 2009 | E-Machines emachines (emachinees) CD-ROM...
CD/DVD Drive Does not read discs
Are you familiar with the Computer BIOS or Setup? The CD may be disabled in BIOS.
Jan 07, 2008 | Toshiba Satellite A85-S107 Notebook
Drive doesn't play CD-ROM but plays DVD games...
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Dec 26, 2006 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
Gateway (5500381) CD-ROM Drive Logo
107 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
