Question about Acer Aspire 5920-6727 Notebook
Blue vertical lines on Vista laptop on Startup
I have a vista laptop. 2 yrs old with blue vertical lines appearing on start up. Have put in safe mode, updated drivers and had 2 gig of extra RAM put on but problem persists. What causes this? How do I fix it as my IT technician and others havent been able to solve the problem. Will it get worse?
    President:
  • 2,600 Answers
They haven't been able to solve it because it is a hardware problem....vertical lines, whatever color are indicative of a failing lcd panel. The lcd panel will continue to get worse until it fails completely. The only other possibility is a loose data connection on the back of the panel, if the data connection is slightly loose, re: one side of the panel is not tightly connected it can give off artifact in the way of vertical lines or checkered blocks.
Posted on May 04, 2010
We have a Gateway Laptop running on Vista. Turned it on this morning and got the "blue screen of death" that said it had a Fatal Error KnownDLL 000021a and a bunch of other numbers. We read that...
Just press and hold F8 on startup (before the Windows logo appears). You should get the screen with the title Advanced Boot Options and the following menu. (which I get on my Gateway NV5915h)
Choose Advanced Options for: Vista (Windows 7 on my Gateway NV5915h)
(Use the arrow keys to highlight your choice.)
Repair Your Computer
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Directory Services Restore Mode
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Start Windows Normally
Description: View a list of system recovery tools you can use to repair
startup problems, run diagnostics, or restore your system.
ENTER=Choose ESC=Cancel
Mar 18, 2011 | Computers & Internet
I have a toshiba satelite laptop a blue screen appears after i try to log in or log into a safe mode or try to repair its vista
You need to boot from a vista disk. or download the vista recovery disk from microsoft and see if it will repair it. something has corrupt the system files. use the repair from the vista cd not the start up repair from the vista boot screen. if it says it cant find a problem then use the system restore points to restore to a time when it worked. you can acces these from the vista cd after it tries to do start u prepair without having to log into vista.
Nov 04, 2010 | Computers & Internet
L355 Satellite Shows Toshiba Logo then goes to Black screen with blinking cursor; after a few seconds two lines appear in top left corner with cursor still blinking. Have Windows Vista (but can't find...
You need your Vista disk to re-install Vista.
If you don't want to go to the expense, download and install Ubuntu, its a free opterating system and now on version 10.4, its pretty good.
May 05, 2010 | Toshiba Satellite Laptop with AMD Athlon...
Compaq presario lap top about 2 yrs old ; power shuts off after turning one and cycles on and off continuously. what do i need ?
You most likely need a repair disk.
Do you have the operating systems disk that came with it? If yes insert than and try booting to repair. Follow the prompt's and you should have an operational pc before long.
Mar 29, 2010 | Compaq Presario 700 470024-192 Notebook
Cant start windows
well u definitely need to reload windows to ur computer, u can get a recovery CD form the company if you r still under warranty, if not u need to pay to get a new recovery cd.. , or you can just get a now copy of windows from computer software store restore your computer
Mar 24, 2010 | Toshiba Satellite M305D Notebook
64bit hp laptop with Vista-Blue screen
You might be using NVIDIA Garphic card.
here is the link fo the fix
http://files.filefront.com/nvlddmkmsysFIX+Brokenrar/;9282195;/fileinfo.html
Download the fix.
Start your system in "Safe Boot" Mode by pressing F8 during Startup.
And installed the fix, Your NVIDIA Card will work fine.
Jan 07, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Asus f9s lcd displays color vertical lines
the graphic chipset on mainboard is damaged,
Aug 06, 2009 | Computers & Internet
Cannot start in normal mode without blue screen popping up
Duing the startup, can you hit F8 just after the bios shows. You should see a list. If you choose, last known good configuration, what happens? If it blue screen's again, can you startup in safe mode? This is also a item on the list from F8.
Did you install any drivers recently, in the last day or two?
If so, when you boot into safemode, uninstall that driver and try to boot to windows normally.
Jul 28, 2009 | Acer Aspire One PC Notebook
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Tom
You should go into the safe mode and try to uninstall or undo the previous work. Else use the system restore. But if it continues again with a blue screen error, then u should format ur pc, further if u experience blue screen error then u should note that one of ur hardware is damaged.
Thankyou...!!!
Feb 08, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5920-6727 Notebook Logo
325 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
