Question about Tunturi T30 Treadmill
The motor is getting louder & louder as you get faster, even at a walking pace. Also a clunking sound. Mat is oiled.
    President:
  • Tunturi Master
  • 832 Answers
Unplug unit remove motor shroud then plug unit in then start it up observe where the noise is coming from. The best way to check the rollers to see if the bearings have failed is using a long shafted flat tip screw driver and place it on the shaft of the front roller, then put your ear on the handle and listen, if the sound has amplified then the roller is defective and needs replacing. If not then check the The drive motor the same way,last but not least check the rear roller by placing the screw driver on the end of each adjusting bolts. this is best I found to eliminate what component if defective. then call your tunturi dealer and either order the part and do it yourself or have their servicer complete the repair.
Posted on May 06, 2010
2005 f150 with 5.4 liter dies when warm,stopping and turning.also has rattle in motor that gets louder
If you were told your loosing oil pressure
WHY WOULD YOU EVEN START THE MOTOR?
You do not assume the gauges are correct
You do the required mechanical testing
to confirm oil pressure
I do not mean to insult you--- but you I'm afraid you
continued to use the vehicle & have ruined the motor
The VVT Cam Actuators fail even with oil flow & lack off
oil will take out the timing chain tensioners & guides
You may as well buy a complete reman motor from Jasper
or other source with a warranty
Aug 12, 2014 | Cars & Trucks
Healthrider H55t makes a clicking noise
Check the front roller. Remove the drive belt and run the motor. If the noise is not there replace front roller.
Jan 01, 2014 | HEALTHRIDER H55t Treadmill with Doorway...
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
I have a ticking noise coming from engine it was low on oil but ive topped up oil and its still there it sounds bad what could i do? its a petrol engine vw golf mrk 4. thanks
If the oil level got too low, it may have caused serious internal damage.
If that is the case, the noise usually gets louder and/or faster, the faster you rev the motor. Only an experienced mechanic can determine for sure exactly what the extent of the damage is.
Oct 14, 2010 | Volkswagen Golf Cars & Trucks
Noise from the rear diff.
What sort of noise have you got ,as most diff noises are due to the Meshing of the Crown Wheel and Pinion as the Pinion can turn at 7 times to the 1 of the C/Wheel and (even a lot more) ,so it wears the hard casing off on the thrust side and causes the whine as you drive and it gets louder the faster you go ,, or if a clunk /clunk/clunk,and goes faster as you drive then its a broken tooth on either pinion or C/Wheel, which you will find if you drain the oil and check the drain plug as most drain plugs have a magnit fitted to them to hold any steel in the oil. RON
Nov 18, 2009 | 2007 Dodge Nitro R/T New Cars
Clunking while driving
Could be a wheel bearing or a cv joint
Sep 22, 2009 | 1998 Honda Civic
Loud sound like jet engine in the cabin. My father believes that it is a broken radial in the tire. I believe it is that or the exhaust. The sound has gotten louder and louder over the past 4 months. I...
It gets louder the faster you go and has gotten worse at lower speeds over the past month. Its a front wheel drive SUV and I had the bearings changed out last month. It is loud as all get out
Jul 20, 2008 | 1996 Chevrolet Cavalier
Tunturi T30 Treadmill Logo
302 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
