Question about Sony Cyber-shot DSC-T70 Digital Camera
Trying to reset the date . i think something may be wrong with the bottom right of the touch screen.
    Champion:
  • Sony Expert
  • 319 Answers
The lcd/touch is faulty replace it
Posted on Feb 01, 2012
While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 test...
I think you'll have to run a factory reset.
However, I cannot find any way of carrying this out. You'll need to contact Ricoh or their dealers, I'm afraid.
Feb 18, 2015 | Ricoh Office Equipment & Supplies
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Feb 20, 2011 | Watches
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
My samsung tocco lite touch screen wont work only the buttons and the camera button work i try and touch something on the screen and if it is at the top of the screen it will move if i touch by the bottom...
same thing happen's to mine, and i'v only had mine for two months :O aha, although i believe it's 'cause i got the screen wet, i mean it's happened before but, usually worked but, this time i think that the water dissolved into the phone making the touch screen not work, mine's still not fixed but, trying taking the phone apart and re-building it. That might help. Kayleigh xx
Jan 15, 2011 | Cell Phones
How do i change the time on the timex 1440 i change it once before but i through the derections away and now evertime i try too change it again it just goes to stop watch so i think i must be doing...
Hi jazzz78d,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Nov 09, 2010 | Timex 1440 Nylon watch
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
I cannot get past the align screen page is there a way of bypassing it?
If it just keeps asking you to calibrate, then that means the touch screen is faulty.
Oct 24, 2009 | HP iPAQ RZ1710 Pocket PC
Need right date and time
Hi there.
Look at the bottom right hand side of the screen where you can see the time, double click on that and a window will pop up, you can set the date and time there.
Good luck and thanks for using FixYa!!
Mar 26, 2009 | Toshiba Satellite A105-S2031 Notebook
The date is wrong
Is the date wrong in your computer or on the website? its unliekly to be wrong ay yahoo, the date and time are probably wrong on your computer have a look into the date and time settings on your computer. (right click on the clock bottom right corner of the screen and select adjust date and time)
Jan 19, 2009 | Yahoo Mail
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
Sony Cyber-shot DSC-T70 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
