Question about Craftsman 8.50 Torque Rating Rear Tine Tiller
Put tiller in till gear, goes fine for 30 sec and jump out of gear. tine stop. How do i fix it
    Sniper:
  • 53 Answers
Try adjusting the linkage or the shifter cable. If its too tight that will happen. I have almost the same one you do. Look at your manual and check out the blow up diagram. there is a way to adjust most models. If not you may need to replace the cable. But...before you do that make sure your cable isn't meeting with resistance somewhere causing it to be too tight.
Posted on May 06, 2010
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Tiller will go into every gear except forward/till..whats going on?
check the shift lever where it goes into the transmission. a lot of times, the lever will get sloppy where the roll pin goes through and it won't shift into till. sometimes you can drive the roll pin out, pull off the lever and peen the holes over. sometimes you have to drill the lever and shaft and put in a snug fitting bolt and nut. OR, the chain driving the tines is broken, and that means a new transmission. hope it's simple
Jul 19, 2009 | Craftsman 8.50 Torque Rating Dual...
I just bought a used Pony tiller. It runs good, but after tilling for a couple no hours the forward and tines just stopped. Had not hit anything. It goes in reverse and the tines work in reverse, but I...
Check under the metal or plastic cover just behind the engine. This covers the forward and reverse belts. Your belt either broke, jumped off fthe pulley, or needs a tension adjustment.
Frank
Jul 04, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Kicks out of till
Best thought is readjust the gear control rod. That or the gears are allready stripped .
May 01, 2009 | Craftsman 8.50 Torque Rating Dual...
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Mar 18, 2009 | Mtd Bronco Rear Tine Tiller
Craftsman 8.50 Torque Rating  Rear Tine Tiller Logo
283 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
