Question about GE Dishwashers
The light `heated, dry` is on because i used the wrong soap, what should I do? thanks
  • abbiagi May 04, 2010
    Hi.
    I appreciate your answer but unfortunately my dishwasher is built in so I can not work under it.
    Do you think this could stop alone if I wait until tomorrow morning?
    Should I turn the energy supply for the machine off?
    Please let me know what to do.
    Thank you very much,
    Antonio
    The machine continue to work, probably trying to digest the soap so it
    makes some noise. You still think that is better to turn the energy
    supply off?
    The machine is not mine so I really feel bad to have put the wrong
    soap, i count on you to lead the situation to a happy ending.
    Let me know if there is anything else I can do.
    Have a good evening
    xx thanks,
    Antonio
    President:
  • 949 Answers
The issue is most likely a full overflow trap which pushes up a toilet-style float and trips a small switch. This effectively freezes the dishwasher in "drain" cycle and for whatever reason puts the panel on Heated Dry. Caused by too much soap or accidental or accumulated inclusion of regular or hand soap (from dishes w/ soap in them in the sink).
Taking off the toe kick and removing a couple panels under the dishwasher lets you barely see the tiny tray that was the culprit, and you can sneak paper towels into one edge of it to dry it out and return it to service.
If you try this you will need to turn the circuit breaker off or unplug the dishwasher first. There are about 15 total screws to remove. It is a bit difficult if you have not worked under a dishwasher before.
Posted on May 04, 2010
  • 1 more comment
  • Philip May 04, 2010
    Hi Antonio,
    Once the suds are gone it will clear out. It may be okay by morning but depending on how bad the suds were it may take a day or two.
    But it will eventually clear itself if left alone.
    Yes, it would be best to turn the power off to the dishwasher.
    Yes, it will be fine, the noise you are hearing is the drain pump running, the suds from the wrong soap has fooled the machine into thinking there is a water leak, so turning off the power will be the best thing so the drain pump does not run all night.
There are soapsuds in the bottom of the dishwasher when the cycle is done
This sounds like the dishwasher got the wrong type of soap. It is a real problem to get the wrong soap rinsed out..follow the directions given by the repairman..it may take 5 or 6 cycles... The jet dry is just an extra in this issue...it will be okay when the soap is fully rinsed out.
Feb 02, 2013 | KitchenAid Architect? II K SERIES KUDK03IT...
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Makes a noise when turned on.. sounds like fan or fan motor.
I would make sure the heater is unplugged then remove backscreen and foam filter. Carefully clean firter with warm water and alittle dish soap. Rinse thouroughly and air dry it. I would clean any hair lint or other debris from fan blades,motor and heating elements. You can use a tooth brush to clean heating elements.You can also use a drop or two of light grade machine oil or WD-40 on blower shaft where it enters the motor. Wipe off any excess oil and when you're sure filter is dry reassemble and try it. Hope this helps you.Thanks
Nov 16, 2010 | Pelonis Disc Furnace Heater
Leaking water through the door bottom left about 6 inchs from side approx 3 tablespoons of water . drying puts heat out in same area causing tile to condensate
The bottom of the door is NOT ACTUALLY SEALED. if you use the wrong or too much soap this can happen. Unit level is important.
Sep 26, 2010 | LG 24 in. LDF 7811 Built-in Dishwasher
There has been a trail of dry soap on inside of door after wash is complete, also dried soap on some dishes in bottom rack as well as not being clean and on top rack spots on glasses and sometimes some...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Hotpoint 24 in. HDA900X Built-in...
It doesn't start and clean light flashes Kenmore Elite dishwasher water supply is turned on overfill protection float is able to move up and down freely there are no sudes in dishwasher soap dispenser...
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Dishwashers
We own a Bosch SHU5307UC dishwasher. Recently, during the 60 minute cycle, the foam builds up and at the end you can see all of it on the bottom. And the last minute dispaly stays on for a while. It...
the unit is over sudzing cut back on soap and dont clean dishes and then put them in dishwasher.dont use to much of the soap with jet dry. regular soap without jet dry in it then add and fill jet dry compartment
Dec 01, 2009 | Bosch SHU5307UC Built-in Dishwasher
Soap dispenser door does not open during wash cycle. it can be opened with the manual release.
close the soap door and put into diagnostics. most models you can do so by pushing heated dry-normal-heated dry-normal. let it do its test and if the soap door opens during the test cycle, most likely the soap door assembly needs to be changed.
Nov 17, 2009 | Whirlpool Dishwashers
Kenmore Elite soap door problem
Dispenser may be bad. Push the hi-temp button , air -dry, hi-temp, air-dry in that order. All lights will lite up and this will do test cycle of all components. If soap disp opens then soap tab may be the issue. I have had intermittent dispenser issues and they are often hard to solve as other components may be at fault.
Nov 28, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap dispensor door opens, but powder soap mostly stays in the cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 15, 2008 | Maytag PDB3600A Built-in Dishwasher
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
