Question about Fujitsu Heating & Cooling
Just turned on my fujitsu air conditioner model number ASU 12D1. Everything works just fine except for a bit of condensation first, and about an hour later continuous water dripping from the front of the air conditioner. Please advise. Thank you.
  • chauhy May 04, 2010
    This is most helpful. Thank you for your assistance. I will look for a local technician.
    This is most helpful. Thank you.
  • 2,427 Answers
Your unit is running low on gas,, caung condensation build up.. normally it will humidify the mositure in the air but cause its running low it will condense on the lines in the unit.. Have a technician gas up the unit for you,, it will solve your issue..
Posted on May 04, 2010
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Trouble shooting a fjitisu wall mount air conditioning unt
Can't troubleshoot if the problem isn't stated. Check the manual for further information.
Sep 08, 2014 | Fujitsu Asu-9d Indoor Ac Fan Coil Unit 1/4...
I have heating cooling unit ASU9RQ. When it works for a half an hour it starts to make a ticking noise that comes and goes.
This could be condensation coming from the coil or expansion valve closing because heat load has been reduced after half an hour causing the liquid refrigerant going through the coil to make a bit of a noise check gas charge to be correct this also is a common cause
Jul 03, 2011 | Fujitsu 24R1 Air Conditioner
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
Hi i am getting an error on my fujitsu aotrcf3l ductud system it is eof abnormal discharge temperature. it was working fine in 42 degree heat 108f and the power went out for about an hour the house heated...
Condenser coil is blocked by full of dust.-Clean it. Fan motor less rpm -Replace capacitor. As you said, 1 minute running compressor due to weak capacitor. Replace running capacitor and clean coil with water and then check. Hope, helpful.
Jan 30, 2011 | Fujitsu Heating & Cooling
Drainage
The amount of condensate it is producing is dependant on how humid the air is it is cooling. The more humid it is the more condensate you have.
May 02, 2010 | Sharp CV-P09FX Air Conditioner
No heat or cold?
is the inside unit in a closet or the attic. if in the attic there may be a float switch in the drain pan and you might have hit it causing the outside unit not to come on
Jan 04, 2009 | Fujitsu 24R1 Air Conditioner
A/C Samsung spilt ( working fine then after 8 hours gives warm air)
It sounds to me like your fan cycling switch is sticking while the unit is cycling off (fans). When this happens your condenser does not have the ability to remove the heat from the refrigerant which in turn causes the compressor to load heavy. This creates a very high pressure condition on the high side. When this happens go outside and see if the condenser fans are running.
Hope this helps You
please rate me
Jul 18, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
