I always use the paper output cassette tray sauce at the front of the printer for printing, the fault developeds when i press print the auto sheet feeder lamp switches to the paper feed sauce at the back of the printer, when i press the auto feeder to switch back to the output tray it will not return, if i load paper into the the guide at the rear the paper jams on the right hand side, paper is not jammed in this feed as ive never fed paper from this point ?
  • stacker01 May 04, 2010
    Hi Lucky4Lynn2,
    my printer is a Canon Pixma iP4200 around 4 years old.
    regards stacker01
  • stacker01 May 05, 2010
    Hello DJ relly,
    thank you for the solution to my printer problem but sadly it did not work, i tried twice just to make sure !
    Guru:
  • 1,051 Answers
Make sure yout printer settings and preferences are not set for any type of speciality paper or envelopes. These settings will, in most cases, change the default feed source.
Posted on May 05, 2010
    President:
  • 4,070 Answers
Hi! Please try this. Unplug the printer from power source then press/hold power button for 30secs. This should reset the printers system. Put the plug again to power source, turn it on and see how it goes. Hope this helps and have a good one!
Posted on May 04, 2010
    Master:
  • 497 Answers
OK, hi my name is Lynn and I will try my best to solve your issue.. First, I need to know more about your printer.. (i.e.: Manufacturer & Model #) OK? Then we can get started. Thanks.. Lucky4lynn2 :)
  • Lynn Carmody May 05, 2010
    what os your Operating System?
    Hello, I did some research & came upon this solution on the Cannon Support Website:
    Change the print feed method in the application
    Some applications, such as Microsoft Word, have a 'Paper Source' setting listed in their 'Page Setup' dialogue box. The setting listed in the application's 'Page Setup' will take priority over the setting set in the driver.
    HOPE THIS HELPS...
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Sep 10, 2014 | Canon PIXMA Office Equipment & Supplies
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
I cant find my manual how to i place the paper underneath so it feeds through the bottom
You can use the paper cassette located at the bottom of the printer, on the front when the output paper tray is closed concealing the paper feed switch, the usb port and the cassette lamp.
1 Gently pull out the cassette from the printer.
2. Remove the cover from the cassette.
3. Place your paper in the cassette tray.
a. when using A5 or larger sized paper (non standard sized paper, pinch the tab and extend the cassette if needed.
b. legal sized paper is not loadable in the cassette
4. Do not load paper above the load limit mar4k.
5. Make sure the print side of the paper is facing down.
6. Align the paper stack against the right side of the cassette
7. Slide the paper guides so they fit the loaded paper stack.
8. The paper cassette will hold up to 150 sheets of plain paper, however you do not eant to stack any more than 50 sheets in the Paper Output Tray.
9. Reinsert the cassette into the printer. Then set the cover on the cassette. Now make sure the cassette is pushed al the way into the printer. (If long paper was used and the cassette was extended iy will now extend beyond the front of the printer
10. Prepare the paper output tray by opening the front cover and pulling out the tray extension until extended completely.
11. Press the paper feed switch so the cassette lamp lights.
You can slo select the paper source with the printer driver if you prefer .
Mar 07, 2010 | Canon Office Equipment & Supplies
We have a Canon Pixma MP600R-how do we perform a self clean?
Hello if you are talking about print head cleaning ,first you have to Make sure that the machine is turned on, then load a sheet of A4
plain paper in the Feeder or the Cassette.After that open the Paper Output Tray, and then open the Output Tray Extension.
(Put your finger in the rounded indent of the Paper Output Tray and open it gently).Press the Paper Feed Switch to select the paper source where you have loaded paper.You are now ready to start Print Head Cleaning.
(1) Select Settings on the HOME screen.
(2) Select Maintenance, then press the OK button.
(3) Select Cleaning, then press the OK button.
(4) Select Yes, then press the OK button.
Print Head Cleaning starts.
Leave it alone for a minute or two.Another window should be open.
(5) Select Yes, then press the OK button.
The cleaning is now complete and you can check the print head condition with the printed nozzle check pattern.
Good luck:)
Jan 31, 2010 | Canon Office Equipment & Supplies
Bottom plate shows leaking ink
If the bottom plate shows leaking ink
1) Cause : Inside of the machine is dirty, printed paper may be smudged.
Action :
a) Press[ON/OFF] to turn on the machine, then remove any paper from the Autosheet Feeder and Cassette.
b) Press the Open Button to open the Paper Output Tray, and open up amd set the extension by pressing down the hollow on the front side.
c) Place the only one sheet of A4/ Letter-size plain paper in landscape, horizontally fol it in half.
d) Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
e) Use right /left arrows to select <BOTTOM CLEANING< from the <MAINTENACE> and press<OK>.
The paper that is loaded in the machine will feed through the machine and be ejected.
If protrusions inside the machine are stained, wipe off the protrusions using a swab or the like.
Important: Before cleaning, be sure to turn off the machine.
3) Cause :Inapproprite media type is used.
* Check to see if the paper you are printing on is too thick or curled.
* Note that smudging may occur at the top and bootm edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless printing.
Refer to the Printer Driver Guide.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
2) Cause : Paper Feed Roller is dirty.
Action : Follow the steps to Clean the Paper Feed Rollers.
Cleaning the Paper Feed Rollers consumes time , so perform this procedure only when neccessary.
A) Press[ON/OFF] to turn on the machine, then remove any paper from the Autosheet Feeder and Cassette.
b) Use [Feed Switch] to select the paper source to clean.
c) Use right and left arrow keys to select <Roller Cleaning> from tbhe <Maintainnace> and press<ok>.
The Paper Feed Roller will rotate as it cleans.
d) Repeat steps c) 2 times.
e) Press the Open button to open the Paper Output Tray, and then open up and set the Paper Output Tray Extension completely by pressing down the hollow on the front side.
f) Load three or more sheets of A4/Letter-sized plain paper lengthways in the paper source you selected in step b.
g) Repeat step c) 3 times.
The paper that is loaded in the machine will feed tthrough the machineand be ejected
If there is not signes of imporvement after performing 3 times, contact the Canon Customer Care Center.
Nov 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Will not print
Cleaning the Interior of the Machine If the interior of the machine becomes dirty, paper printed onto by the machine may get dirty, so we recommend performing
cleaning regularly.
Note: Ensure that the Inner Cover is closed.
1. Press <ON/OFF> to turn on the machine, then remove any paper from the Auto Sheet Feeder.
2.Press the Open button to open the Paper Output Tray, and open up andset the extension by pressing down the hollow on the front side.
3.Prepare a single sheet of A4- or Letter-sized plain paper. Fold it inhalf along the long edge. Unfold the paper, then load it in the AutoSheet Feeder with the open side to the front.
insertfoldedpaper.gif 4. Start bottom plate cleaning.
  1. Press <COPY>.
  2. Press <Menu> repeatedly to select [4.MAINTENANCE].
  3. Use [left.gif ] or [right.gif ] to select [BOTTOM CLEANING], then press <OK>. The sheet of paper is automatically fed in and then out of the machine.
Ifthe printed paper is smudged, clean the inside of the machine again. Ifthe problem remains after performing cleaning again, the protrusionsinside the machine may be stained. Clean them up.
Note:Even if the Cassette is selected as the paper source, paper will be fedfrom the Auto Sheet Feeder. Do not perform any other operation whilethe bottom plate is being cleaned.
Cleaning the Protrusions inside the Machine
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or the like.
I hope it helps!!!
Nov 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Brother printer problem
Manual Feed Command.
1. Press the Job Cancel button to cancel the print job. Delete the print
job in the print queue on the computer. You can quickly access the print queue by double clicking the Printer icon in the task
tray or dock.
2. Turn the printer power switch OFF on the right side of the printer.
Check that the front cover is closed.
3. Turn the printer power switch ON while holding down the GO button
until the Toner, Drum, and Paper LEDs are lit.
4. Release the GO button. All LEDs will be off.
5. Press the GO button 8 times. The green Status LED will flash briefly
while the printer is reset. After the printer is reset the Status LED
will be lit green.
6. Print the Print Settings by pressing the GO button three times. If
the Print Settings pages do not print and the Paper LED is on again skip
to the next section - No Paper in the Paper Cassette.
If the Print Settings pages print, the problem is isolated to printing
from your computer. The Paper Source of the Brother printer driver or
program you are printing from may be set to MP Tray or Manual, instead
of Auto Select, Tray 1, or Tray 2 (if the optional paper tray is
installed). To check the Paper Source setting of most programs, click
File and Page Setup or Page Layout. You may need to click the Paper
Source tab or Paper tab depending on your software application. Verify
that in the Paper Source section does not list MP Tray or Manual. Choose
Auto Select, or another relevant source such as Tray 1. Click OK. Try printing the document again.
No paper in the paper cassette.
1. Pull the paper tray completely out of the printer.
2. Insert the letter or legal size paper into the paper tray with the
top edge of the paper first and the print side down. Make sure that the
paper is flat in the tray and below the maximum paper mark. If using a
paper size other than letter or legal, the paper should be loaded in the
MP Tray. The MP Tray can print on paper from 2.75 in. by 4.57 in. up to8.5 in. by 16 in.
3. While pressing the blue paper-guide release lever, slide the paper
guides to fit the paper size. Make sure that the guides are firmly in
the slots. For legal size paper, press the lever located at the back of
the tray and pull out of the back of the open tray.
4. ReinstalI the paper cassette back into the printer. Press the GO
button. If the alarm clears, no further troubleshooting is needed. If
the alarm continues, follow the steps below.
Paper Jam at Paper Pick-up.
1. Turn the printer power switch OFF on the right side of the printer.
2. Remove the paper cassette from the printer.
3. Elevate the front of the printer slightly to locate the jammed
paper.
4. Gently remove the jammed paper.
5. ReinstalI the paper cassette back into the printer.
6. Turn the printer power switch ON. If the alarm clears, no further
Oct 02, 2008 | Brother HL-2040 Laser Printer
52 people viewed this question
k24674
jasbo
jasbo
