Question about Mtd 22" Yard Machine Push Mower
Lawn mower pull cord
MTD 3.5 HP 20'' lawn mower pull cord has disconected inside. How do I fix it?
  • 61 Answers
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
  • 118 Answers
Replacing the pull rope on a push mower is pretty. First of all remove the air shroud usually 3 screws, on some units after removing the shroud you will need to remove the rewind unit it self. Remove the rope from the rewined mechanism and lay it aside. Now rewind the unit by hand until it is tight then back it off to align the hole. Use a c clamp to hold the spool. Measure the rope roufly do not cut yet. Insert the rope. and tie the knot.Ease off the c clampand let the unit rewind. Put unit back together inreverse order.
Posted on Mar 15, 2011
How do I fix a transaxle in a turf trac lawnmower that is tough to change gears in?
Could it have an object jammed inside the shifting arm or it could actually be bent just enough over the years from wear and tear.
Sep 24, 2014 | Mtd Garden
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
Fixing a cord recoil on a mtd mower with a 4 hp briggs and stratton engine
The upper covers and the fuel tank needs to come off, the starter on most engines is part of the engine cover so this will have to be un bolted and removed with the starter connected
May 30, 2013 | Mtd Garden
Belt diagram for 46" mtd yard machine riding mower
You can find the belt diagram for the MTD Yard Machine mower in the MTD Owner Manual. The diagram is on page 21.
Feb 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
Recoil will not pull. The walk behind MTD,Yard Machine mower, a B&S 500 Series stalled while mowing. I went to restart and pull cord will not pull more then a few inches. How do I go about the fix?
If all the safety gear is working on the mower; Possibly sounds like you let it run low on oil and the engine is locked up.
Which would mean a new mower.
Sep 29, 2009 | Mtd Garden
I have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Sep 17, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
1,661 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
