Question about Maytag Washing Machines
How to remove coins from under the drum on maytag bravos
SOURCE: removal of agitator Maytag Bravos series, have
Give this discount appliance repair parts company a call. They offer free do-it-yourself advice and sell discount appliance parts
Here's the link to their website:
AAAPartsToday.com
Their phone number is right on the homepage.
Posted on Jun 19, 2009
  • 155 Answers
SOURCE: Ld error on Maytag Bravo. How to remove items stuck under tub?
if you can see the socks you may be able to remove by making a wire hook with an old coat hanger or something similar if you are able to undo the hose coming out of your bowl to the water pump you may be able to also fish out the coins if you are lucky but the best way is to dismantle bowl let me know how you went
Posted on Nov 07, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: We have a Maytag Bravos
It won't go directly to the drain pump, there is a filtering plastic screen beneath the wheel.
steps:
1: unplug the unit and open up the cover at the back
2.: you will see the bottom of the drum with a wheel connected to it, hold it tight (you'll need a helper)
3: while somebody is holding it at the back, go to the fron and you wheel the bolt on top of the wheel inside the tub, Un-bolt it
4: once the bolt is remove try to lift the wheel upward using the right left right left motion upward, do this slowly and carefully, remember do not turn the wheel JUST LIFT it side by side
then you will see if there a coin or whatever is blocking the drain, when you put it back, same procedure what you did taking it out only this time you PUSH downward
Posted on Nov 08, 2009
barkencoa
  • 3463 Answers
SOURCE: I can hear a coin rattling under the drum of my
If I were you, I would leave it, and it should find it's way into the filter.
To try and remove it is quite an involved task.
Please rate my solution.
Thanks.
Posted on Nov 19, 2009
SOURCE: I have a 2 y/o Maytag Bravos MVWB700VQ0
it is probably money in the pump. I have had my washer for two years now and an on the second pump. I had to call a serviceman to take the pump loose and dump out the change. It had 81 cents the first time and 26 cents the second. I need to call him again but I think I am going to try to do it myself. $85 a service call is just ridiculous when I know what the problem is.
Posted on Oct 15, 2010
I have a maytag bravo and it making a humming sound and wont drain water
There isn't much I can add to Gordon's Appliance solution.
thats exactly where I'd go for the solution .
Dec 11, 2014 | Maytag Bravos MTW6600T Top Load Washer
Have a Maytag Bravos XL MEDB9504WO that works, but very noisy. Bought a pulley that sits on top of
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Jul 31, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos washer will not complete cycles
Remove clothes from drum. Siphon out (or wet vac out) visible water in the drum. Blow into drain hose. This back flushes the system. After hearing gurgling and seeing bubbles come up thru the drum, you know its a fairly clear line. Now take your wet vac and siphon out remaining water by connecting it to the drain line using duct tape. The lights will correct themselves and your washer will now work normally. At least this is how I fixed mine without disconnecting anything or making a big mess. Good luck.
Apr 17, 2012 | Maytag Bravos MTW6600T Top Load Washer
How do i get the change out of the drum of bravo 300
I'd try laying in some double sided tape...not pressed in there but just make ya a loop down at the bottom and run it in the spin cycle a few seconds..
If the coins come out, maybe they can catch on the tape.
Jul 17, 2011 | Maytag Bravos MVWB400V Washer
Coins are getting under the agatator and falling into the drum. And from there to the pump Which i have replaced once.It seems that the water ports are to large. Is there a fix for this problem
take the coins out of pockets before placing clothes in washer. a new pump must have cost about a hundred dollars. i was able to repair mine using epoxy putty and a nylon bolt and nut, about 5 dollars.
Feb 03, 2011 | Maytag Bravos MTW6600T Top Load Washer
We just installed a new Maytag Bravos dryer and right from the beginning it "thumps". The service tech said he may need to replace the drum. On a brand new unit never ran, we are having a...
did you call the factory,if it's under a year it should still be under warranty,you shouldn't have to pay a thing,i would have a problem with that too.
Oct 30, 2010 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
I have a 2 y/o Maytag Bravos MVWB700VQ0 top-loading washer that is suddenly making noise like there's either a) a chain loose in the drum of the machine, or b) a coin or other metal object is bouncing...
Oct 12, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
I have a coin under the drum, Is there a easy way to remove it.
To tell you the truth, with front loads there is no easy way. But what you need to do is take front off, remove boot from door, take out inner tub and then you'll see ur coin. But what I would do is let it get to the pump assembly first before you get into it.. It should make it's way there, when it does it would be easy for you to get it
Feb 26, 2010 | Maytag MAH8700A Front Load Washer
We have a Maytag Bravos top load washer, and coins have gotten into the drain pump.(We think) It sounds like coins being moved around when it starts the drain/spin cycle. How do we remove them. Model...
steps:
Nov 08, 2009 | Washing Machines
Removal of agitator Maytag Bravos series, have coin(s) that rattle in the spins cycle
AAAPartsToday.com
Jun 19, 2009 | Maytag Washing Machines
Washing Machines Logo
225 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
