Question about Koss KS2503 System
I've got the optical cable hooked up but am not getting any sound from speakers... what output does the box need to be on to play from another source via the optical cable
    Brigadier General:
  • 8,546 Answers
You need to choose the correct INPUT that the optical cable comes from, whatever that is. Have you looked at the source?
Posted on May 04, 2010
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
How to connect a vizio lcd hdtv to my 1976 kenwood KVA 503. My Vizio has no speaker outputs except a digital optical audio. I had it hooked up before and then moved and now I can't get it back...
Obviously the digital optical connector was never connected to the vintage Kenwood.
It sounds like your Vizio is NOT the actual root SOURCE of the TV audio but it's coming from a Cable Box which DOES have various audio outputs. Connect it as you would any other analog audio source (except don't use the PHONO input).
Jun 30, 2011 | Audio Players & Recorders
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
I don't get sound from Vizio Sound Bar, need connection instructions.
You have a red and white composite audio cable the simplest way is to hook that to your audio output on your tv then obviously the other end goes into the soundbar. Make sure its an OUTPUT not input on the tv, if you hook it up this way everything that plays on your tv will then play through the soundbar.Some tv's do not have an audio output if this is the case then you will have to hook it up to an output of another source such as DVD player or cable box. There are two other possible audio outs on your tv they are fiber optic audio and digital coaxil audio but usually not the case as they are usually only inputs. One other thing some tv's(very rare) require you to go to menu to enable audio out. There is one other possibity and that is HDMI which carries picture and sound but again TV's rarely have this output.
Dec 13, 2010 | Vizio Televison & Video
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
I hooked up a htz510 home theatre system to my tv and it sounds great when I play dvds. However, in pure tv mode, my tv plays through the tv speakers instead of the home theatre speakers. How do I fix...
if you use cable and have a cable box or sat. and have a box you need to get an optical audio cable and hook them between the to boxes. just did this with mine today
May 23, 2008 | Televison & Video
Need help hooking up to digital cable box, and tv
If the cable box isn't transmitting surround sound your stereo won't play it. You may be able to emulate it with settings on the receiver.
Jul 23, 2007 | JVC TH-C50 System
Koss KS2503 System Logo
87 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
