Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
HOW DO THE SPRING ATTACHED TO THE SAFETY BAR BACK IN SLOT; IT APPEARS TO BE TO STIFF TO COMPRESS BY HAND
  • dontbother10
    dontbother10 May 11, 2010
    Hello Rob; Answer what model husky below and I can most likely answer your question. I think you need to reassemble and release the chain brake. Am I correct? If I am correct I still need a model number, if not a better description of your problem and the model number.
    Brigadier General:
  • 4,088 Answers
Try compressing the spring with a Channel-lock type of pliers, hold it over the slot and use a small hammer to tap the spring into the slot while keeping the spring compressed. Good luck!
Posted on May 07, 2010
Lockout Follower bar and spring location for Paslode 900420 Nailer
you can try going to paslode.com and downloading a breakdown of this tool. The lockout bar and spring go under the metal plate on the side where the pusher spring is. You have to remove the nose piece (2 screws) and lift the metal plate. Towards the bottom there is a slot that the spring goes in and as you are holding the spring push on the back side and lay the lockout bar in place. Replace the metal plate and hold in place to ensure these parts more freely. Reassemble tool. Let me know if you need more assistance.
Mar 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
How do i put the nail pusher spring back in the hitachi framing nail gun
Remove all bolts holding the rails to the body of the gun (make note of the position of the parts as you take then off ). Slide out the pusher assmbly. If the spring is good (wound tightly and has the bolt hole), hold the pusher assmbly in hand and attach spring to body of gun leaving bolt loose. Slide the pusher back into the rails and attach rails to body of gun up against the bolt (snug down bolt and check spring action). Re-attach rails to gun. Some after market rails do not have the slot cut into front allowing easy install of spring (cut slot with dremel). Good luck
Sep 12, 2011 | Hitachi NR83A2S Framing Nailer, Full Head,...
Won't Start, back-fires through carburetor, took off sump cover and camshaft lines up correctly with crankshaft but exhaust valve is loose and doesn't have any tension when cam lobe is on the flat side....
I once made a valve spring compression tool out of a sliding bar clamp from my woodshop the ones with the flat bar the clamp slides on not a pipe clamp because it wont let you close enough. then I ground a U shaped slot in the stationary head to allow it to slide over the valve stem then you can crank the other end to compress the spring
Mar 15, 2017 | Garden
The chain saw (2050) starts up but the safety bar seems to be stuck in the brake position
Grab the hand guard and pull it fully back to the main top handle, it may take a reasonable amount of force as it is compressing a fairly large spring inside the brake.
Mar 11, 2011 | Poulan 14" Chainsaw
Diagram for parking brake cables
Removal & Installation
  1. For the 1500HD, relieve the tension from the park brake cable by pulling down on the park brake cable in front of the equalizer then removing the cable from the equalizer bar.
  2. For the 25/35 series Disable the park brake cable automatic adjuster.
  3. Raise and safely support the vehicle.
  4. Remove the tire and the wheel.
  5. Perform the following procedure to remove the cable (2) from the backing plate (4):
    • Compress the spring (3) by pushing toward the lever (1).
    • Depress the locking tabs.
    • Pull the cable housing out of the backing plate (4).
    • Remove the cable (2) through the slot in the backing plate.
      Lever (1), cable (2), spring (3) and backing plate (4)
  6. Remove the park brake cable (2) from the lever (1).
  7. Remove the rotor.
  8. Remove the rear axle shaft.
  9. Remove the park brake shoe return spring (6).
    Park brake shoe assembly 1500HD, 25 and 35 Series
    Click to Enlarge
  10. Remove the park brake shoe anchor springs and pins.
  11. Separate the tips of the shoes from the park brake actuator and remove the park brake shoes and adjuster assembly from the vehicle.
To install:
  1. Clean the debris and the dust from the park brake components using a clean shop cloth.
  2. Install the adjuster assembly to the park brake shoes.
  3. Separate the tips of the shoes and install the park brake shoes to the park brake actuator.
  4. Install the park brake shoe anchor springs and pins.
  5. Install the park brake shoe return spring (6).
  6. Adjust the park brake shoe.
  7. Install the rear axle shaft.
  8. Install the rotor.
  9. Install the park brake cable (2) to the lever (1).
  10. Perform the following procedure to install the cable (2) to the backing plate (4):
    • Compress the spring (3) by pushing towards the lever (1).
    • Route the cable (2) through the slot in the backing plate.
    • Push the cable housing into the backing plate (4) until the locking tabs snap into place.
  11. Install the tire and wheel.
  12. Remove the safety stands.
  13. Lower the vehicle.
  14. Enable the park brake cable automatic adjuster.
  15. For the 1500HD, install the park brake cable to the equalizer by pulling down on the park brake cable in front of the equalizer then installing the cable to the equalizer bar.
  16. Adjust the park brake cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; shinehutt_0.gif
Jan 13, 2011 | 1995 Ford F150 Styleside Regular Cab
The spring is so stiff that I can not switch from hold to unhold mode.
Are you talking about the brake? It is supposed to be locked back, so when the saw kicks up it stops the chain from chopping your head off. If this is what you are talking about,, grab hold of the safety bar and yank it back hard. So that it locks back. Now you should be able to let go of it.
Jun 22, 2010 | Husqvarna Chain Saw 20" Bar
How to install the peg perego car seat adapter on
You have to put the big bar through the wholes in the side attachments first before attaching the spring loaded bar. The big bar should be facing toward the front of the stroller.
Once the bars are all attached, the to clicky slots on the Peg should click into the small cross bar and the spring loaded bar. The big slot on near the back of the Peg should rest on the big bar.
Mar 05, 2010 | Baby Jogger City Series Single Stroller
'93 Olds 88 brake reassembly. Very stiff spring.
put the bar on the shoes before you attach the clips and springs.
Oct 04, 2009 | 1988 Oldsmobile Delta 88
What locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Sep 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
1993 Toyota Corolla rear brakes
While you have the lower spring compressed, reach behind the backing plate and turn the pin to line it up to the slot, instead of turning the spring. Good luck. Hope this helps.
Apr 25, 2009 | 1993 Toyota Corolla
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
91 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
