Tv blew the tube fuse (4amp)blew and a yellow box with ss42025/03 on it sparks every time we put in a new fuse. We were watching tv and a pop noise happened and the tv turned off
  • Jango Fixit
    Jango Fixit May 11, 2010
    Please tell us what the make and model no. of the TV is.
    Is the tv in a humid environment, did it just begin to rain when the problem happened?.
    How old is it.
    If the transformer mentioned here (996500029760 TRANSFORMER CONV.SS42025-03 PHILIPS ) is a high voltage transformer, please be very careful because they produce 30,00 volts. Don't go near it when the juice is flowing.
  • 236 Answers
SOURCE: Popping noise
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Posted on Mar 03, 2007
  • 556 Answers
SOURCE: Sony Bravia XBR-2 32-inch LCD with popping noise problem
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Posted on Sep 24, 2007
Slinteriors
  • 8617 Answers
SOURCE: Sparks
Thats the CBA board heres a link where you can get one but its expensive.
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/313926720561/New.aspx
Posted on Mar 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
Posted on May 18, 2008
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Posted on Sep 22, 2008
My Klipsch cs 500 has no sound. Blue light is on and I have tried every combination on remote to no avail. Any ideas?
There is the panel mounted 4amp fuse, and then there is a circuit mounted 6amp inline fuse as well. Mine blew due to a power surge that blew up other things in my house as well. It’s a bear to get the circuit board screws off, and some green sealant off! Step 1) I’m ordering a panel mounted fuse holder that is the same style as the 4amp fuse holder. Step 2) drill hole in panel, and install fuse holder Step 3) no need to remove old fuse (since its blown) so I’m soldering wires from new fuse holder to the fuse ends on the circuit board
Oct 29, 2017 | Klipsch Audio Players & Recorders
Heard a loud pop noise on Toshiba TP48D90 tv.Now no sound
Its not worth it. the parts cost alone will exceed the value of the Tv. you can buy a new 50" TV for $500 or less. Time to put it out to pasture.
Jun 01, 2015 | Toshiba Televison & Video
1987 pontiac bonneville spark plug wiring diagram
It doesn't seem to me it is a routing problem. I think you have a spark plug wire leak instead.Replace wires.
Feb 22, 2018 | 1987 Pontiac Bonneville
Fuse keep blowing
Means that item the fuse is protecting is bad.Fusing unit is a good start replace it
Apr 01, 2010 | Office Equipment & Supplies
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
