Question about Vornado Circulating Fan
How to take apart a vornado fan model 183c for cleaning
3 Suggested Answers
  • 12 Answers
SOURCE: I want to clean a
There are three clips the hold the grill to the cowl.
Look along the outer edge, on the back.
One clip at 11 o'clock, one at 2 o'clock and one at 6 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shold come off.
Posted on Mar 12, 2011
SOURCE: Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Posted on Jul 08, 2011
Need to take appart vornado to clean
It depends on what type of unit you have. There are grill clips on the back of the unit that you will need to depress. Some models have screws that need to be removed in order to remove the grill. If assistance is needed please call us at 1-800-234-0604.
Thank you,
Vornado Helps
Oct 24, 2012 | Vornado Dryers
I have a Vornado floor f an, the blades iof which are coated with heavy dust. How do I remove the front protective screen to clean the blades.
On the model I have, the front grill just pulls off from the front; there are some tabs that you might need to release by pushing with a small screwdriver from the rear. After cleaning, just align the tabs and push it back in until they click back in and latch.
Oct 24, 2010 | Vornado Circulating Fan
I want to clean a very dirty Vornado circulating floor fan but I don't see how to get it apart.
Oct 09, 2010 | Vornado Circulating Fan
Need to clean..............how do I get it apart to clean model 280SS Have had this model for quite sometime and it deperately needs a cleaning. THNAK YOU!
There are four clips the hold the grill to the cowl.
One clip at 11 o'clock, one at 2 o'clock, one at 4 o'clock, and one at 8 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shuold come off. The clips are just tabs molded into the grill, don't push too agressively, or the tab will break, and the grill will not latch on as well. Check the Vornado website for more information. They used to have a video about cleaning.
Use mild soap and water the clean the blades after removal.
Sep 14, 2010 | Vornado Circulating Fan
3 speed standing fan. #1 the blade barely rotates.#2 a little faster. #3 it starts slow then speeds up like it's going to take off. It also makes an annoying sound like it's rubbing on something or is...
It is the motor. Probably needs cleaning and lubrication.
You can send it to Vornado.
It is not hard to get apart, just draw a diagram of what color wire is what speed.
You "could" do it yourself.
Jun 10, 2010 | Vornado Circulating Fan
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've been able to remove the front grill & clean it and the blades, but now I'd like to remove the rear...
It's similar to the 600 and 700 series based on a picture of those compared to the 280b model I have. http://www.vornado.com/product-support/support/faq.aspx
Jul 04, 2009 | Vornado Circulating Fan
Jul 03, 2009 | Vornado Circulating Fan
The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
Jan 19, 2009 | Vornado VH2 Compact Heater
HOW DOES THE SPRING RESEAT FROM BASE TO FAN ON VORNADO 750?
If the spring has a long tang and a short tang, the short tang goes under the clip that holds it down and the long tang goes between the stand and the back of the cowl. Tell me the model and I can send a pic of one assembled. Here is an image of a newer model 750 with the spring correctly installed. d9080401-0828-41f7-adc8-a32265f6077f.jpg
Jul 12, 2008 | Vornado Circulating Fan
Vornado Circulating Fan Logo
2,250 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
