Question about Ryobi Factory-Reconditioned 30cc 18" Gas Hedge Trimmer ZRRY30550
RYOBI BC 30 TRIMMER WILL START AND IDLE BUT WILL NOT ACCELERATE. BOGS DOWN AND THEN DIES. CARB NEEDS ADJ? IF SO, HOW?
boscia
  • 163 Answers
SOURCE: ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Posted on Nov 29, 2008
  • 8 Answers
SOURCE: ryobi BC 30 trimmer bogs down with throttle
some have to warm up, although there should be a gas/oil mix screw on the carb try adjusting it
Posted on May 12, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 112 Answers
SOURCE: ryobi 410r cultivator needs intital carb adjust
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Posted on Jul 15, 2009
94cobra
  • 3 Answers
SOURCE: Ryobi gas trimmer SS26, won't start hot
My solution is to stop buying lawn and garden equipment from the local home centers. I too made the same fatal mistake you folks made. I bought the SS26 model Ryobi weedeater used it about 3 or 4 times and it has turned to ****. I am so pissed off I will never buy any power landscape tools from home centers again. I even bought a Troybuilt gas powered hedger and I have to work on it for 3 hours in order to use it for 1 hour. I will start buying commercially available professional gas powered landscape equipment from now on. I learned my lesson the hard way, just like you. The gas was bad??!!??!... I have used oil mixed gasoline in a lot of my two stroke eqiupment for 12 months without additives and it always burns just fine. The last Ryobi weedeater I had was 15 years old before it gave up the ghost. Thats why I bought this new one. I never had to use fresh gas everytime I used it...What a joke....I say we little people ban toghether and pass the word along to everyone we know about how junky their equipment is and how unreliable the companies are in supporting thier product. The problem with the SS26 Weedeater is the carbureator (spelling) it is an inferior piece of junk...period. After 4 uses, it will only start up, as soon as I pull the gas trigger, it dies because it leans out. I checked the spark plug (another piece of ****) and it looks like the machine was running hot, The electrode was a whiteish color indicateing a lean burn condition, nt the chocolate brown I was hoping to see. I hope this helps everyone who reads this... Spend a couple hundred extra dollars and go buy something real. Stop playing with the kids toys. This is what I am going to do to resolve the problem. They don't care about us, why should we care about them....Down to the firey pits with them....
OVER.............
Posted on Jan 15, 2010
Ryobi weed eater stalls when giving it gas
check air filter and spark plug if good carb adjustment is needed or carb may be loose. could be bad fuel water in gas will cause this
Aug 26, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi BC-30: no draw through carb when attempting to start?
This Can Be Solved By Checking The Vacuum For Any Dangorous
Content Such As: Gas,Oil, Mini Pieces Of Steel From Spark Plugs.
Kevin.
Aug 24, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I Have a Ryobi Trimmer. I cleaned out the carb and put it back together but forgot the High and Low needle settings. I have got it to start but am having trouble tuning it. I have put a carb kit in it and...
adjust the needles both all the way in until they stops. unscrew both 1 1/2 turns and start engine. slowly accelerate and if it bogs down unscrew the HIGH SLOWLY until full speed is gain. some times you have to unscrew a little the low speed too. is a matter of playing with it. be patient you will get it. if you are still having problems you may have to take the bottom of carb. out and make sure the gas inlet needle is letting pass gas into the carb. chamber.
Feb 16, 2011 | Ryobi Garden
Saw will start and sometimes idle as soon as you accelerate bogs down and dies
Check and clean air filter first.If this does not work you will need to rebuild or replace carb.
Nov 19, 2010 | Poulan Garden
Ryobi CS30, will start but when I pull on the throttle trigger it bogs down.
i had same problem. i did a few things - cleaned muffler, replaced fuel line and filter (home depot sells a $7 kit) and in the past i replaced the head casket.
Mar 13, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 will start but when I pull on the Throttle trigger it bogs down, good spark plug and filter is good. I have the same problem. Cleaned everything and even put NEW mixed gas in and still does not...
Check the fuel lines first for cracks. If they are cracked or brittle, replace them. Also, your carburetor may need cleaned. Use a Den Tek Brush, (used for cleaning between teeth), to clean the small portals. Make sure the small screen in carb. is free of debris. The smallest of particles can cause your problem. Reassemble and try starting. If it still acts up after all this then you will have to purchase a carb. kit and replace all appropriate parts. If you need tips on these remedies, feel free to ask.
Jim
May 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi BC 30 trimmer bogs down with throttle
May 07, 2009 | Ryobi Garden
Ryobi Factory-Reconditioned  30cc 18" Gas Hedge Trimmer ZRRY30550 Logo
207 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
