A salesman with a local amana dealer sold us a heat pump. he told us it was a 3.5 ton top of the line but now it is installed it has a note saying it is model ASZ 130421AA. Please explain the different information. jim thomerson jim@thomerson,com
  • 2,427 Answers
Ok click this link
http://www.amana-hac.com/Portals/1/pdf/SS/SS-ASZ16.pdf
BTW the model is
Amana Heat Pump ASZ16 R-410A
the tag u gave is just the model and series,, it matches back to the above.. In that link you will find everything u need to know..
Posted on May 04, 2010
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
I would like to know how to replace the heat strips in an Amana GPH1330M41 unit
Buy a heat kit from a Goodman dealer. Check that your existing wire will carry the amp load.
Jan 17, 2014 | Goodman Manufacturing Goodman GPH1330M41...
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
Camcorder only operates for 3 seconds in playbaco
HAVE YOU CLEANED YOUR HEADS LATELY? THIS HAPPENED TO ME, AND LOOKED AT VERY EXPENSIVE HEAD CLEANERS THAT I WAS TOLD WOULD ONLY WORK. I SPOKE TO A SALESMAN AT OUR LOCAL RADIO SHACK WHO SOLD ME ONE FOR $2.00. IT WORKED GREAT AND TOOK CARE OF THE PROBLEM.
Jul 16, 2010 | Panasonic NV-DS65 Mini DV Digital...
Had heat pump replaced roughly a month agoworked fine until yesterday.the wife says it was 85 degrees on the thermostst when it was set at 78. Told her to check breakerfreon line at air handler and...
call the install company back out. along with the new heat pump i wouls say they installed a leak. you stated r12 i assume you ment r22 if they installed an r22 unit and didnt change the a coil it might not be their work leaking but the a coil might be. at any rate once you have them fix it i would look for a new service company i would never install an r22 system any more the EPA is phasing it out and the replacment in my opion is beter
Jun 26, 2010 | Goodman CLQ36AR49 Air Conditioner
Installing Windows Mobile English ROM
open the case. **** in it. slam it down. there ya go all nice n english
Apr 13, 2009 | Samsung Cell Phones
Amana Heat Pump Emergency Heat will not come on
the problem sounds like 1 or 2 things either you have a bad sequencer for the heat strip or the emergency heat portion was not wired up.
Jan 30, 2009 | Amana PTH123B25AJ Heat Pump Air...
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
