Question about Carrier Heating & Cooling
Water pooling inside furnace unit
I just had my a/c units serviced for the season a few weeks ago. For the last few days I have had water pooling inside the furnace unit. At first I thought my hot water heater was leaking (b/c it sits right next to the furnace) but today I heard what sounded like water flowing inside the unit, pulled off the front panels and yes there is water...what could it be?
  • kbarthmaier May 04, 2010
    What does undergassed mean? From what I saw the service guys do, they checked the freon, one unit was fine the other needed half a pound, they cleaned out the condensers outside, they checked air flow (pressure?) with some gauges, they came in and made sure the air flow was clear inside the furnace part and cleaned off some dust. Nothing else has changed, now just what sounds like running water in there. Is this something that would be covered under my home warranty?
    Makes sense -thank you very much!
  • 2,427 Answers
Well more than likely your ac is undergassed, causing condensation and eventually water.. get the gas checked in the unit.. I have a strong feeling they didnt gas it up propperly or it sprung a small leak..
Posted on May 04, 2010
  • Rishi Roshan Ali May 04, 2010
    by undergassed I mean that the gas is to little or doesnt have enough pressure.. Did they pump in a dye to check for leaks ??? chances are there is a micro fracture caused by the servicing.. Call them back.
Error message Fault. High Limit , upon attempting to use the heater for the first time this season
either not enough water flowing through heater or low gas pressure to overheat unit replace high limit in stack if not one replace one on bottom white unit with 2 white wires
May 26, 2016 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Turned the heater unit on, the burner lit and after a few seconds, it shook violently for 30 sec, then there was a bang, the furnace went silent, the flame went out breifly but then it lit again. Is...
Sounds like you had insufficient water flow through the heater causing the water to boil inside the heat ex-changer. The Hi-Limits should have turned it off almost instantly. There is an internal by-pass, almost like a thermostat in a car radiator that could have been stuck. I would need to know if this was a one time thing or it happens everytime you fire the heater.
Aug 13, 2011 | Raypak 266K BTU Digital Residential...
I purchased an INtex 9 x 18 Rectangular Pool less than a month ago. Th "all in one system" works fine when you select the "FP" (Filter Pump) cycle. However when you switch to the "salt water system" cycle...
Service light is not fixable by the consumer
you will need to call intex
they will e-mail you a form fill it out and fax it back to them
you will have a new pump in a few days to your door
it must be under 2 years old and you must have a valid receipt
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
Why does my furnace gas valve keep going bad
Check the ground wire to the gas valve or the wire in the middle of the gas valve that says mv--pv, and that is a ground..
Dec 19, 2009 | Heating & Cooling
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Green light not working on Intex Saltwater System, model #8110
It is easier to explain than to type it all out you can call me at 586-625-2300
we have never had any issues with water clarity
in general I will say you are not filtering enough in normal mode
Mark
Jul 08, 2009 | Intex Automatic Salt Water System for ...
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Water dripping (almost running) out of the left corner of air handling unit. Help???
You're correct in checking the drain pipe, because it's become blocked. The only trouble is, you're trying to clear the wrong end. The condensate water is spilling out of the air handler because that's where the pipe has a clog. These pipes usually have un-glued joints next to the air handler, for times such as this. If you can't pull them apart, you may have to cut the pipes and reconnect tham with fittings from the hardware store. (which is a normal procedure.) I usually use a wet/dry shop vac when repairing this problem, sucking out the clog & the water, then blowing out the line to where it drains outside. I've also used the clothes hanger technique to drag crud out of the air handler fitting. Hope this is helpful. ;)
Aug 10, 2007 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
126 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
