No picture anymore
Suddenly no picture anymore, light indicates that the monitor is receiving electricity. Connections are secure in place
  • pnswelsh May 04, 2010
    This is a new Samsung LCD model SnncMaster 953BW attached to a Gateway GT4016 personal desktop computer. The computer was bought at the store not quite three years ago. The Samsung monitor was bought at the store about 9 months ago.
  • Chris Hingee
    Chris Hingee May 11, 2010
    Is this monitor a CRT monitor or a LCD monitor?
  • 32,281 Answers
First connect the monitor to another computer to see if the monitor is faulty.
If the monitor is faulty and less than 12 months old and may be still under warranty.
If so I would get it repaired under warranry, if you try to repair it yourself then you could void your warranty.
Posted on May 05, 2010
  • 11,361 Answers
LCD or CRT type monitor?
If it is LCD:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 04, 2010
Checked connections, all good. Tested with another Winplus monitor, it works . The car battery was changed since then monitor has no picture but power button is on (blue). Menus not working either??????
If another monitor works in place, it sounds like you've found the culprit. If the other monitor works completely normally, and you aren't even seeing menus on that monitor, AND the power button is blue (which normally indicates powered and in use), it sounds like the back light or some internal connection on that monitor is bad. Hope that helps and good luck!
Jun 17, 2014 | Winplus BT1326572 Wireless Vehicle Backup...
Monitors green light comes on but can't get picture
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as a faulty electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard Check the vga lead for secure dust free connection or try another vga lead. Hope this helps.
Dec 29, 2012 | Compaq Presario 5000 PC Desktop
No picture or anything, but is getting power.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Nov 25, 2011 | Samsung B2430H 24 inch LCD Monitor
The monitor suddenly went blank and displayed "no
Try to pull out video card and clean the slot on motherboard then put video in. If no result replace video card.
Feb 01, 2011 | HP Pavilion 6730 PC Desktop
The power supply works and I get a green light that my connection is being received but I get no picture! I can see the picture for the first 1/2 a second when I turn on the monitor but then it goes blank....
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | Computers & Internet
Suddenly, the handheld monitor turns off (no picture or sound) and will not turn back on, even when I plug in the AC adapter. The green light on the battery indicator is on, but the monitor won't turn on...
Mine jut did this. What did you end up doing. I did what other people said which was take the battery our and put it on the stand... NOPE... green light on but not sound or picture. I could hold the button down until the cows come home and it will not turn on.
Sep 23, 2010 | Summer Infant Slim Secure Handheld Video...
No pic on monitor
Check all the connections to the monitor, ensure they are all intact, replace any cable suspected to be damage and see if there is difference, if no difference, this indicate that the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 19, 2010 | NEC MultiSync LCD1512 Monitor
Picture Freezing on Flat Screen TV
The symptoms you describe are indicative of a weak signal. If all your connections and cables are in good order, then you may need to either adjust your aerial or place a booster into the system.
If you have had no problems up until recently, it would suggest to me that something has changed to cause this. The normal problems are corroded connections at the aerial, or the aerial has rotated due to wind etc.
If you choose to put a booster into the aerial system, put it as near to the aerial as possible.
If you already have a booster in place, is it working?
Regards
Zahc
Jun 15, 2010 | Televison & Video
Monitor
Generally an indication the monitor is not receiving a signal for the computer.
  • CHeck cable connections on monitor and tower
  • Insure input select on Monitor is set to AUTO or the input you are using
  • If you are getting windows sounds and other indications of boot, then a monitor issue, if no sounds, may be aproblem with teh computer or windows
Sep 21, 2009 | LG L192WS LCD Monitor
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
