Question about Sony PlayStation Portable (PSP) Console
How to reboot psp - Sony PlayStation Portable (PSP) Console
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 364 Answers
My friend too faced same kind of problem............
his ps3 get stuck and never turns normal soon.....until its been restarted
if you are also facing exactly same problem
then dont worry
Go to this site and fix your problem bydownloading repair guide
Click Here to Get guide
Posted on Aug 22, 2010
  • 140 Answers
Hold the power up for 10 seconds and it will reboot the psp.
Posted on May 07, 2010
    Problem Solver:
  • 5 Answers
HOLD R1 key and turn on the power. Voila
Posted on May 04, 2010
Tip
How to hack a psp without pandora ?
Since ChickHEN is out PSP-2000 owners with a TA88v2 or less or a TA90v1 motherboard now have the option to now install Custom Firmware without the need of a Pandora battery.We have put together a Easy installer that contains everything you’ll need. Hellcats Recovery flasher, ChickHEN, PSP firmware update 5.00.
Warning make sure you only try this on a PSP that will accept PSP Custom Firmware flashing (Custom IPL) otherwise you will brick your PSP!!! PSP-3000’s will not take CFW. Check your PSP will take CFWhere. Or run ChickHEN first, then when ChickHEN is loaded run PSPident from the Game XMB menu. (PSPIdent with install with this easy installer)
Steps to install CFW on a PSP Slim without a Pandora battery.
1. Check and triple check you have a hackable PSP that will accept
custom firmware flashing without resulting in a BRICKED PSP. Make sure you have a PSP with a TA88v2 or below only + or TAv90v1. If your PSP has a TA88v3 or above or is a PSP-3000 DO NOT proceed!!! You will brick your PSP.
Run the installer and point it to your Memory stick Pro Duo root.
2. If you don’t have don’t have PSP firmware 5.03. Get that here: PSP Firmware 5.03 Make a folder called UPDATE in your PSP/GAME folder and place the eboot in there on your memory stick pro duo.
3. Now lets run ChickHEN to have a homebrew enabled environment. In your PSP go to photo then click the ChickHEN photo and wait. If the PSP jams, please retry. If it flashes colours and reboots you have loaded ChicKHEN. Check your system info to be sure it say’s 5.03 ChickHEN R2. If you need help getting ChickHEN to run please visit this post.
4. Now with your PSP rebooted in ChickHEN go to your PSP XMB game menu and run Hellcats Recovery and install 5.00 M33!!! Your PSP will reboot, follow the instuctions to install PSP Custom Firmware 5.00 M33. After your done you can update to 5.00 M33-6
Easy ChickHEN CFW installer (Without Pandora) (27.9 MiB,)
visit www.newzgadgets.co.nr
on Mar 10, 2010 | Video Game Consoles & Games
My psp froze on the internet and it whont unfreeze.
Reboot it by sliding the power button to off and holding it there. If it still doesnt shut down pull the battery out then hold the power button for 10 seconds. Put battery back in and reboot. Also check to make sure that there are not any updates available for your PSP
Mar 07, 2011 | Sony PlayStation Portable (PSP) Console
When I insert a new UMD i get the game could not be started. 80020148. The UMD is recognised and the thumbnail appears on the menu, but the game will not start. Please help.
Solution: 1) You must first backup ur data on your memory stick to your PC. Mainly the saved games data. ( directory is PSP\SAVEDATA) 2) Format the memory stick using the PSP format tool in system settings...not your PC. 3) In System Setting UNCHECK or UNSELECT "UMD Cache" this must be off!!!! 4) Connect your psp via USB cable 5) Copy your game saves / data back to your psp remember >> PSP\SAVEDATA . 6) Do a hard reboot of your psp ie hold the power switch for 3 seconds and it will reboot. 7) Your UMD games should now work with no probs.
Nov 25, 2010 | Video Game Consoles & Games
My psp was downloading 6.1 software and i bumped it and it shut off and wont turn on
You do have custom firm ware ( CFW ) if you have memory card then you can get the 6.1 software from the web site and put it on your memory stick then put it back into you psp reboot it while holding the right triger gose into recovery mode then exit out i do this when my psp bricks its a safe reboot.
then instal the new update
Oct 20, 2009 | Sony PlayStation Portable (PSP) Console
How do i reboot my psp?
Have you tried turning on, but then hold the power switch down for around 10-15 seconds or until the power light simply turns off, no flashing. If not, then you should jump on the internet and look for a so-called Pandora Battery and Magic Memory Stick. They will actually install custom firmware on your PSP which you can remove later on, but if you use those, it should unbrick the PSP, so you can use it again.
Sep 24, 2009 | Sony PlayStation Portable (PSP) Console
Cannot get games to play-where is the "OASS Button"?
Try this:
This is not my solution, just a solution found on a messge board from others having the same problem
Apr 23, 2009 | Sony PlayStation Portable (PSP) Console
Rebooting my psp
well to reboot it just turn it off and then back on again.
during the update i got for it a day ago it asked if i wanted to reboot and it automaticly reboot itself. if you can't turn your psp off or on, check the battery or get a new one.
hope i helped a little... good luck :)
Jun 08, 2008 | Sony PlayStation Portable (PSP) Console
Psp
press "Home + Select" to power off. And press "Home + Start" to reboot
Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
205 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
