Question about Polaris Ranger RZR Ride on Toy
Why does it seem to die very fast and only spins one wheel most of the time? When I lift it up, both wheels spin but not when he drives it. The battery runs dead in a matter of minutes but when i charge it and meeter on it, it reads 24 volts?
    Genius:
  • Polaris Master
  • 1,508 Answers
Check the charger and make sure that its putting out more than 24 volts
Posted on May 14, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
Posted on Jun 03, 2009
  • 156 Answers
SOURCE: Power
The battery seems to be bad. I get my Peg Perego Batteries at http://www.shopjandl.com/
My batteries last about 3 to 5 years, as long as my kids are charging them up each time they go down.
Hope this helps
Posted on Jul 10, 2009
Possible reason why 04 chevy tahoe 4wd works up in air on lift but not on ground
the residual force makes it look like its working on a lift ,
check your wheel sensors the speed sensor determines how fast each wheel is turning say in the snow , if the sensor fails it wont go into 4 wheel drive.
Feb 19, 2015 | Cars & Trucks
When my car is stuck in the snow and doesnt seem to get traction only one wheel spins and not the other and its front wheel drive wouldnt both spin?
No, even a 4x4 will have only 1 wheel that will spin on each axle in this instance. It's called a floating differential. For stock vehicles with non locking differentials like you have, both cannot spin or have full power at the same time. Hard to explain on this, but picture your car making a hard right turn. Both front wheels would be spinning at different speeds because of the turn. The passenger side tire is spinning much slower than the drivers side tire, therefore if both were spinning at the same time, your tires would chirp and skip on the pavement which would eventually ruin your differential. In offroad applications, we WANT the differentials locked and turning at the same time with true 4x4. But in normal everyday vehicles, even standard stock 4x4's, only 1 tire will do the spinning per axle unless it has possitraction or full locked axle. Clear as snow?
Mar 13, 2014 | Ford Taurus Cars & Trucks
Vibration when accelerating and in a turn but more when turning left in my ford f150 2 wheel drive super-cab
Sounds like a front wheel bearing. Try this, lift up the front end, grab the wheel, hand on top and bottom. try shaking the tire. it shouldn't wobble. if it does, theres your issue. if its tight, try spinning the tire as fast as you can by hand and listen, chances are you'll here it. Good luck!
Apr 25, 2011 | 2004 Ford F150
Why do my antiloks engage when the wheels spin in awd?
The vehicle computer's Traction Control System (TCS) has detected wheelspin on one or more wheels that's greater than the detected speed of the vehicle. That is, it knows you're spinning the tires and not going anywhere (or not really going that fast). It compares the rotation of all wheels to that of the slowest moving wheel (or slowest wheel that has a sensor), and slows down the faster of the bunch. Since it's not a full-time 4-wheel drive (where all wheels move the same speed all the time), it allows some wheelspin for outside wheels around corners, but keeps the wheels in check with the brakes. Some Traction Control Systems rely on cutting engine power to stop wheelspin, while others activate the brakes on the faster-moving wheels.
Mar 09, 2011 | 2003 Chevrolet Astro
Noise in front end 2002 zr2 blazer
Two things maybe your problem:1 .Front axle actuator to engage 4wd is not releasing. 2. Front axle u-joint needs replacing. Lift car on jacks with front end off ground. Then spin tires by hand as fast as you can and see if you hear the noise and where it is coming from ( spin in both directions).
Feb 04, 2010 | 2002 GMC Sonoma Extended Cab
Noise at rear wheel. Sounded like warn disc brakes. I replaced the disc brakes. Less noise but still not acceptable. Could it be a wheel bearing and if so how do I tell?
lift the rear axle off the ground and spin the wheels around as fast as you can. if the bearings are bad you will hear it if the sound changes as it spins. If it a scratching noise that will be from the disc brake pads
Jan 24, 2010 | 1999 Jeep Grand Cherokee
Speedodmeter does not work after tire change
remove the cable from the drive at the wheel lift the front wheel spin it see if the drive spins around if not you have a problem with the drive if it spins you have a broken cable pull the inner out and check it out if thats ok you have a faulty speedo meter
Oct 08, 2009 | 2001 kawasaki Super Sherpa
Rear scraping sound, Also when placed on lift and in gear (all wheel drive) the rear left wheel does not spin
Take it in for proper diagnosis - that's not supposed to happen in an 'ALL WHEEL DRIVE' - all WHEELS ARE SUPPOSED TO TURN.
May 20, 2009 | 2004 Hyundai Santa Fe
Rear wheels not spinning. Front wheels spin when in 4 drive.
Hi First of all check the adjustment on the rear wheel thats sticking sometimes the brake pad comes away from the metal it is fixed to this maybe the case on your vehicle, the make & year of vehicle would help further but I a sure you got something to check now. Please leave me feedback, Malcolm Campbell.
Sep 23, 2017 | 1994 GMC Sierra
Polaris Ranger RZR Ride on Toy Logo
129 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
