I tried to download music on my mp3 and it said i did not have no more space ans sys erased.
  • 593 Answers
Solve your MP3 Player Connection Problem.
See this tip posted here on this site, it is one of the best here for this type of problem.
Posted on May 04, 2010
Cannot delete all music files on MP3 player
http://www.p4c.philips.com/files/s/sa178_07/sa178_07_fus_aen.exe
try to download and instal this firmware and go for a thorough format..
Feb 07, 2010 | Philips GoGear SA178 MP3 Player
Will turn on but message appears saying "Not enough space for music DB. Please free 30mb." then shuts down.
I had the same problem two days ago.
Working on the assumption that the problem was a corrupted file, here's how I fixed it. As you'll see, I connected my Clip an Macintosh computer to fix it, but there is probably an analogous procedure using a PC. But I'm not very PC savvy, so someone else will have to figure that out.
Also, I don't know that all the following steps are needed, for example, trashing the old content folders and creating new ones, but this is what I did, and success resulted:
Connect Clip to Mac
Click on Clip's icon to open it.
Open up all content folders and drag songs, audiobooks, podcasts, etc. to trash and empty trash. (The idea is to get rid of the corrupt file, wherever it is.)
Drag all Clip system files to a new folder on the Mac desktop to copy them. This will include DID.bin, RES_INFO.SYS, SYS_CONF.SYS, version.sdk and WMPInfo.xml (Basically, I copied everything that wasn't a content folder.)
Don't bother copying content folders AUDIBLE, AUDIOBOOKS, MUSIC, PODCASTS and RECORD. (Later, you'll create new folders to replace these, to ensure that no corrupted file is reloaded to the Clip.)
Go to the Mac's Utilities folder. Launch "Disk Utility." Select Disk Utility's "erase" function. On the left, where disks are listed, select the Clip. Click on the "Volume Format" dialog box and choose "MS-DOS filing system." (Don't bother with any of the erase options, such as replacing all data with zeroes. Just do the basic erase.) Erase the Clip.
When erase is completed, drag copies of Clip's system files from Mac desktop back onto Clip icon.
Use "new folder" function to create new AUDIBLE, AUDIOBOOKS, MUSIC, PODCASTS and RECORD folders on the Clip.
Eject Clip from Mac and note whether the screen shows the Clip "refreshing" normally. If it does, you're in business.
Jan 23, 2009 | SanDisk Sansa Clip MP3 Player
Synchronize to continue your music subscription I got my mp3 player for christmas and was using Rhapsodys free 30 day trial . I down loaded several songs . Now I have this message and I cant hear my...
(to clear or 'erase' skip to format -below)
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
Most other problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 03, 2009 | SanDisk Sansa Clip MP3 Player
Omnitech mp4
Make sure the files are in the correct format
May 20, 2008 | iLO (2 GB) MP3 Player
Scan disk sansa c200 series locked with an error message
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa problem plz help
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Mar 03, 2008 | SanDisk Sansa e260 MP3 Player
"MTP DB Mismatch Format?"
The Insignia NS-DA2G needs to be placed in File & Folder mode, and you'll need to have your mac show you all files on the device. Macs will create a smaller file that starts with "._" that contain very little information, but can cause problems with Windows based or Windows preferred devices. These files are not ignored by the PC or certain Windows optomized devices. You should erase these files for the unit to perform normally.
If you are unable to delete these files, you can re-format the device to FAT-32 and that will erase all information on the device. You shouls also hit the reset button (located next to the "HOLD" switch) for about 5-10 seconds to clear the internal settings.
Jan 10, 2008 | Insignia NS-DA2G MP3 Player
Not enough space can't download any music!!!
uh, how about you erase old music you dont like or listen to?
Dec 27, 2007 | Nextar MA933A MP3 Player
Adding or Removing tracks from my player
Yes, it could have quite a bit to do with that (even though I love BearShare).
Here are ways to delete:
or
-Tha Mp3 Doctor
Aug 26, 2007 | SanDisk Sansa e260 MP3 Player
Open Questions:
20 people viewed this question
 Grubhead
Grubhead
