My washing machine stopped in the middle of a load and my clothes are still sitting in water. Any ideas what could be wrong?
  • 1,998 Answers
Start with checking the lid switch if you dont hear the click when u open and close the lid replace unit does nothing if lid switch is in op beside let water in
Posted on May 04, 2010
Tip
Washing Machine Problems and Repairs
Washing Machine Problems & Repairs If your clothes washer needs repair, you can begin your troubleshooting here A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader. The four cycles that every washer performs are fill, wash, drain, and spin.
Though there are a number of problems that you can fix quite simply, washing machines have a variety of devices and controls that, when they go wrong, are better left in the hands of an appliance repairperson.
Some problems that commonly occur with a clothes washer are that it doesn't agitate; doesn't drain; doesn't run; shakes, vibrates, or moves; doesn't spin; the water temperature is wrong; or leaks.
If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
If it doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a washer to shudder or “walk.” If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Because washing machine hoses are under constant pressure, check periodically for wear because they can flood your home if they burst when you're away. You can prevent this by installing lever-type shutoff valves (shown top right). With these, you can easily turn off the levers for both hot and cold water between wash days.
on Sep 03, 2010 | Washing Machines
Wont spin drain or engage
Need more info. Brand, top load or front load, or full model number. Thanks.
Jan 19, 2013 | Washing Machines
Whirlpool GSQ963ILL0 top load washer. Stopped dead in middle of agitate cycle. I fear I overloaded it. Now just sitting, full of clothes and water, and won't do anything. Any advice?
Hi jim_zervas,
Firstly, unplug the machine. Then first thing to do is remove the clothing, and bucket the water out. Then run the machine again.
Let me know what happens?
Kind Regards
JEDEMEYER1
* Please accept my solution if it solved your problem
Sep 03, 2011 | Whirlpool GSQ9631L Top Load Washer
Stops and shows flashinng OE when I open door clothes are sitting in water
IE: Water level (246) was not reahed in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermister out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
Service manual and more HERE
Jan 05, 2011 | Washing Machines
The does not spin when put few clothes
Some do not wash with a small amount of clothes. It is recommended to add more clothes. The idea is saving water and energy by not washing one thing at a time.
Some various errors for front load washers:
middle of L. Upside down F) Thermistor out
PF: power failure momentary interruption of shocktricity
Dec 31, 2010 | Washing Machines
My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
Jun 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Thumping hitting front stops on wash cycle.
if it was not NEW and under warranty, you bet i would ask for your paid service in heartbeat.
the repairman is arriving finally tonight.i will update what he finds.
Apr 05, 2009 | GE Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
