Question about Whirlpool LER4634J Electric Dryer
Fire in my dryer
What do i do about there fire coming through the heat holes in th back of my dryer?
    Novelist:
  • 145 Answers
I wouldn't use the dryer for now. It sounds to me like you have a lot of lint build up in your dryer back by the heating elements which is catching on fire. It is a very hazardous situation. You will need to disassemble your dryer and clean all the lint out from around the heating elements and your vent pipes as the fire can spread into your vent pipe.
Posted on May 04, 2010
Kenmore Elite gets hot, dries clothes but the metal piece in the back of the dryer is burning holes in our clothes.
This is URGENT.
What you described is a precursor to a dryer fire.!!
Dryers work this way....they have an air intake that allows the heated air to come in, circulate around the clothes, and an air outflow that the heated air flows out of. Look in your dryer, you will see the two separate intake and outflow behind grills onside the dryer. Look for burn marks. Open the dryer and look straight back to the intake and outflow grill where the hot air flows in, then out of the dryer.
What happens when your exhaust system is blocked is that the air becomes superheated, and (if a gas dryer) flames can come up to or into the dryer through that metal part you are describing. If electric, it is superheating and burning the clothes. I would bet your exhaust is clogged somewhere. Fix this before using the dryer again.
You can call a repairman to do the cleaning and check this out.
OR try to handle it yourself with a few easy steps.
Check the flow of air where the exhaust comes out, usually outside your house or apartment. If the flow is weak, its a definite sign of a clog...usually in the exhaust duct that is usually a flexible metal tube that attaches to the bottom of your dryer, then winds its way outside to a vent....but a fire can come from something else being clogged.
Try this:
1) Clean the lint trap
2) Replace the exhaust ducting (they are very cheap and easy to install on each end)
3) If you can, with the dryer disconnected form power, take the back panel off (it's very easy) and look for dust and lint buildup that can come from a clogged vent, then vacuum it off. If you see burned lint there, then that is proof you have had some fire.
If the above is not your problem, you need an expert to come and diagnose this.
Good luck
Mar 07, 2014 | Kenmore Dryers
Flame goes out after 20 seconds
when was the last time you cleaned out the dryer and vent line?if the dryer can't move the air the heat will stay in th dryer and the heat won't run for long because the dryer is hot and up to temp.you should clean out the lint filter duct,the cabinet where the motor is and if the vent line is long remove it from the back of dryer and blow it out with a leaf blower.i've seen dryers catch fire if they haven't been cleaned out.this is the prblem most of the time,people start changing parts and all it is is lint blocking the vent line or the duct that the lint filter slides into is blocked with lint.start here and see what happens
May 16, 2013 | Maytag HYG3460AWW Gas Dryer
GE dryer, no heat?
Your heating element is most likely burned out . Have you made certain all of your lint vents for the dryer are not clogged ? Also , be certain to clean the lint filter every time you use the dryer. A buildup of lint in the dryer , in the hoses & on the back of the dryer inside in between the drum & the outer covering can get so hot it will catch on fire when the heat is working , and also , without a fire will burn up your heating element.
May 18, 2012 | Dryers
On my Kenmore Soft Heat Heavy duty gas dryer I am having problems with the the fire lighting and going off intermentently . The fact that it ignites and then goes out makes me think that it isn't...
Hello Jerry,
It is working like its supposed to when the flame goes off, the way all dryers work is the flame(heat element on electric heated dryers) comes on and when the drum exhaust temp reachs a maximum of 155degrees and the flame goes off, the air temp will cool off to 120degrees and the flame comes back on and cuts off once again the 155 degrees has been reached..much more that 155 degrees the clothing is very likely to combust and catch on fire.
Please reply and let me know if your having a dryability issue with your dryer or where you just concerned since the flame went off??
GENE
Sep 05, 2011 | Kenmore Dryers
We have an LGR8648 gas dryer. When you start the dryer, it heats up just fine. At some point (after 15-20 minutes, it seems) the burner goes out and never comes back on. Is there a thermal sensor or...
The most common cause for your problem is the gas valve coils. There are 2 and should be replaced in pairs. Over time, they will fire when you first start the dryer but fail to fire again once in mid cycle. A link for a typical set of coils is listed below:
Whirlpool Gas Valve Coil Set of 2
Jul 24, 2011 | Whirlpool LGR8648 Gas Dryer
No heat
make sure th switch on th "fire wall' where the 2-small hoses come out is moving when th "temp control switch" hot & cold is being moved on control panel,, or change the thermo-stat...
Apr 09, 2011 | Hyundai Elantra Cars & Trucks
Kenmore 70 gas dryer no heat
your thermostat controls the heating
Jun 11, 2009 | Kenmore 62802 Electric Dryer
No heat..gas not fire up
My Whirlpool has a thermal fuse in back in the air duct in case the lint filter doesn't get cleaned.
There are other causes too----
Apr 25, 2009 | Dryers
Dryer heating problems
If this is a gas dryer, this is commonly caused by bad gas valve solenoids. Please post back with your make and model so I can verify your configuration and assist you further.
Jan 25, 2009 | Dryers
Fisher and Paykel DG09 dryer
Wow, sounds like a major safety issue and possible fire hazzard to me. Try contacting the manufacturer of your unit and do it before the warranty runs out so you have full warranty benefits. Good luck.
Jan 14, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool LER4634J Electric Dryer Logo
66 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
