Question about Whirlpool RBS245PDS Electric Single Oven
Oven wont heat
Replaced electronic control and everthing works fine except that oven will not heat. the electronic control seemed to have a burnt spot and smell to it. outside breaker did not kick. wondering if oven shutdown thermal fuse blew?
    President:
  • 949 Answers
There is a temperature activated thermostat (TOD) that is located on the back of the oven that would explain the problem you are having. The part can be checked with an ohmmeter and should read 0 resistance if it is good. The part number is 9759243 if your model number in the description is accurate (RBS245PDS)
Posted on May 04, 2010
I have a bosch Oven model HBL745A UC and the heating element at the back of the oven won't turn off.
Most likely part is the oven control board, it has relays on it . There is one stuck. IT is 2235 dollars to replace.
Dec 09, 2013 | Bosch HBL 745 Stainless Steel Electric...
Just baught the stove a little over a year ago and everything works on it except the heating element for the oven quit working one day just like that. i can hear everything in the back clicking like its...
have you checked the continuity of the heating element if there is no continuity then it needs to be replaced,you also need to check the wiring to the element and make sure it is good if all is good on that end then you will need to replace the electronic control.
Nov 12, 2010 | Ovens
My electric oven wont heat up
check the breaker box first, turn breaker off then on. then try oven again
check the timer, sometimes the timer gets set to delay and oven won't work
second, with oven off trace entire element with finger to see if there are any burnt spots.
if no burnt spots found, there may be a burnt wire leading to element in the wall behind
please, don't forget to rate my solution.
thanks
Jun 22, 2009 | Ovens
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
Oven Not Heating Up
the control panel, has a relay that controls the heating in the oven, it's not closing ther circuit. the electronic timer/control panel, has to be replaced
Apr 21, 2009 | Whirlpool RBS275PD Electric Single Oven
Lower oven does not work. Ind. light comes on but no heat
It sounds like your heater element is burnt out. Get a volt meter.unplug the stove.take off the back,disconnet one of the wires connected to the element and test it. It should read aproximately 11 ohms if good. if a high or no readind,the element needs replacing.
Feb 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electric wall oven will not heat up
This is ovenmad from the previous post. I had a repair guy come out and he found the problem to be the Safety Thermostat. When tripped, this allows everything to work on the oven except the elements. He did not have the part with him so will return in 6 days to replace it. That should solve the problem. No idea why it tripped. The safety thermostat is located on the rear of the oven so we will have to pull out the oven to replace the thermostat. Again, this was a Frigidaire Single Electric Wall Oven made in 2004. Hope this helps somebody else.
Dec 22, 2007 | Frigidaire FEB27S5A Electric Single Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Whirlpool RBS245PDS Electric Single Oven Logo
200 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
