Question about RCA P52926 52" Rear Projection Television
PICTURE BLANKS OUT AFTER TV HAS BEEN ON A WHILE
Picture blanks out when changing channels from direct tv input
If it is just a momentary blank out then that is normal dpending more on your signal and so on and not as much the tv. If it blanks out and stays off then you have a problem with the reciever section and should contact Samsung or the store for repair information.
Apr 23, 2010 | Samsung DLP HL-P5663W 56" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The picture blinks three times and then blanks out but the sound remains
This sounds like your monitor back light is not working. If you look really hard at the screen, can you see a very dim picture? If so the back light isn't working. This is almost always an inverter problem and can be fixed.
Jan 13, 2010 | Samsung (TN-RBNG10) TV Input
Tv keeps blinking to black screen and back to normal. (sony trinitron)
Probably the picture tube getting weak, those sets have a circuit called IK Blanking that samples the three colors of the picture tube and if they are not equal the circuit blanks the picture. Another clue is if occurs less frequently the longer the set is on because the picture tube can get a little stronger as it warms up.
Aug 28, 2009 | Televison & Video
TV blanks out..."pcm" light flashes on receiver
You need to Bypass the Receivers HDMI port and use HDMI directly to the TV. Your receiver has HDMI version 1.2a and is not 100% effective. Use the optical out from your Xbox to the receiver and all will be well. 1.2a has issues in every receiver on the market. Supposedly 1.3b on the "new" receivers has fixed this issue. Hope this helps
Aug 12, 2009 | Yamaha RX-V663 Receiver
Screen goes black every few seconds but have a picture
Sony incorporates a video blanking circuit that blanks the picture out when the picture tube begins to get weak. sorry, but short of replacing the tube, there's no lasting solution to this problem. I used to have some success rejuvenating the crt, but I found that it didn't last but a few hours before the blanking circuit starts to activate again.
Apr 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tired with this sony tv
Sony doesn't want anyone to see a poor picture on a Sony tv so they have a circuit that blanks the video if there is a weak picture or any other problem concerning picture quality. My Sony factory Instructor told me this many many years ago. I'm feeling old...but anyway you need a technician. Sorry.
barneyluc
Oct 03, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Screen blanks out
A digitalizing picture is most likly a bad connection on a screen driver cable or the driver itself is intermittant or the power supply has an intermittant filter on the substain B+ line. hope this hellps.
Oct 08, 2006 | Sampo PME-42S7 42 in. Plasma EDTV
RCA P52926 52" Rear Projection Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
