Question about GE Spacemaker JVM1640SJ Microwave Oven
No response to control panel commands.  Control panel is lit but oven does not work.  Problem occurred after power outage on my street.  I have removed and reinserted plug.  I have turned circuit breaker off and on.  Fan works and panel illuminates when oven door is opened. Clock also is off.
  • 229 Answers
Since the lights work, fan works and the light turns on in the microwave I don't think it is a fuse. You have lost the controls on the touch pad. With the power surge it appears that the the panel circuit board was damaged with the power outage. There is a one year warranty on this component. An authorized repair shop can replace it for you for about 120 dollars. I hope that help you out. The Part Number is WB27X10070. Roughly 60 dollars and labour is 60 dollar (1 hr)
Posted on May 04, 2010
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
Counter top lights not working. new bulbs replaced. still not working.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 04, 2012 | Panasonic NN-H275SF Microwave Oven
A small blinking light on the left upper corner of panel after a power outage and I can't do any command. The interior lights don't even come on when opening door. I already reset the breaker
Unplug the microwave oven for 10 minutes in a attempt to reset the microprocessor ic, press and hold the start button for the same time and release. Now plug everything back in hopes it will restart, if no change! the keypad control board will need to be replaced along with other unknown parts, due to the nature of damage far cheaper to replace.
May 09, 2012 | Microwave Ovens
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
Touch screen not responsive. Can operate oven only by pressing one-minute button. Cannot set clock, change settings, etc.
try opening up the control panel,disconnect the connector ribbon coming from control panel and connected 2 control board by just pulling it out and cleaning end of connector ribbon and iserting it back.some times this works.if not then 4 sure touch panel needs to be replaced.
Aug 15, 2009 | Kenmore 63792 Microwave Oven
My KHHS179LSS-3 will not let you control microwave from touch screen un pluged unit plug back in touch error high fail low fail appears on screen
I was afraid I needed to replace the microcomputer when my KHHS179L touchpad was unresponsive. I was able to use the ADD A MINUTE feature, so I knew the unit worked. There had been a power outage of less than a minute to my home recently (I was unaware of this until I asked the kids if they had done anything to the microwave). I popped around on fixya.com and really didn't find an easy solution-my favorites. I loaded kitchenaid.com and found the answer in the FAQ's. Although the control lock out icon was NOT LIT-apparently, that power surge locked my controls. By holding the stop button for 5 seconds once and then aagain a second time, miraculously, my touchpad was restored> HOORAY!
Jul 10, 2009 | KitchenAid KHHS179L Convection/Microwave...
Danby DMW753W ; machine starts without any command
The membrane of the touch control is shorted and must be replaced.
Mar 27, 2017 | Danby DMW773 Microwave Oven
LCD panel dimly lit, microwave works fine.
You have two options for this model:
We can repair your control unit for $39.95 in about a week or you can order a modified control unit with our proprietary upgrades for $115, then if you return your defective control unit in repairable, good cosmetic condition, we'll give you a core refund of $30.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 03, 2009 | Dacor DMT2420SS Microwave Oven
Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Sep 11, 2006 | Goldstar MV-1526 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
47 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
