Question about Kenwood Car Audio & Video
I have a kenwood excelon kdc-x715 cd player that was working fine til all illumination turned off as well as power to cd changer. what could be the problem?
robotek
  • 1512 Answers
SOURCE: Kenwood KDC-3028 unlock code
Hi there, there is a standard procedure we use to bypass the code when we have the gear on the test bench for repair. Try this and it should sort out your problem
You need the remote control to do this, if you don't have one, then you may need to go to a KENWOOD agent and get them to clear the code for you, or purchase one for your use.
KENWOOD SECURITY CODE CLEAR procedure Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
The security is canceled and the set enters the TUNER mode!
A FixYa rating would be fantastic for helping you out with this techo tip.:)
regards
Graeme
Posted on Apr 14, 2008
SOURCE: Kenwood car radio/cd player Model No KDC-3027
Do you like need the colors codes for the harness like speakers and and all?
Posted on Nov 20, 2008
JustJeeps
  • 74 Answers
SOURCE: Security unlock code for kenwood excelon kdc-x990
Call 1800kenwood there is a default code but you need the remote to enter it
Posted on Nov 21, 2008
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Posted on Dec 09, 2008
SOURCE: Kenwood KDC-C717 - E-99 error
There is probably a jammed disc or disc holder. It cant eject the cartridge because the unit cant put the disc back into the cartridge to the left.
Took me a about 20 mins gentle persuasion after removing the plastic front (carefully depress the little plastic clips on the edges and (again, gently, lever the front off) and removing the metal case - half a dozen screws each side and remove the bottom. The top stays fixed to the workings. I could then get into the gap between the top case and workings but be careful not to pull the unit from the rubber antishock mountings etc. and remove the problem disc.
I removed the plastic fascia which surrounds the magazine hole too, not sure if it was necessary..!
Again - be careful not to be rough with it, you dont want to snap the plastic clips, etc and also check the horizontal/vertical adjusters are back on in the correct position if they come off.
Posted on May 16, 2009
Can someone please tell me what color wire on the back of the head unit is the REM wire? It's a Kenwood Excelon X559 series. thanks
Amplifier remote turn on is blue/white, power antenna remote turn on is blue. The power antenna remote turn on turns off when leaving tuner mode.
May 12, 2011 | Kenwood eXcelon KDC-X559 CD Player
I just bought a 1994 bmw. I need a code to access my kenwood kdc-x679 excelon player. The previous owner doesn't know the code,
You can enter a 4-digit security code which must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational.
If the code is lost or forgotten I am afraid the unit has to go to a Kenwood dealer for re-coding.
Mar 26, 2011 | Kenwood eXcelon KDC-X679 CD Player
My Kenwood Excelon KDC-X559 does not power on at all. I know that it is getting power though. You can insert and exit cd's from the unit but that is all it will do. Screen does not show power at all. Is it...
are you sure you have power going to the red wire? the red wire needs to be connected to a switched (ignition) power source. the radio will not work unless both the red and yellow wires are getting power.
Mar 06, 2011 | Kenwood eXcelon KDC-X559 CD Player
I have a kenwood eXcelon KDC-X759 and after i hooked it up it just kept flashing code off, and it will take a cd but no sound and the radio works fine
does the cd seem to be working other than no sound? if so, are you running the audio through an amplifier? if you are using an amplifier, you may be using the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) to turn the amp on. when using the antenna remote wire it turns off when going to cd mode.
Aug 13, 2010 | Kenwood eXcelon KDC-X759 CD Player
When i turn the car on the control panel on the Kenwood excelon KDC-X769 jus starts on opening and closing but never stays opens
you may have a bad face position sensing lever inside the deck, or bad gears. it could even possibly be bad flexible cables.
Jun 20, 2010 | Kenwood eXcelon KDC-X769 CD Player
I have a Kenwood Excelon KDC-X890 and somehow the AUX feature for my IPOD on the deck got turned off. How do I turn this back on?
From the stand by mode push the menu button. Scroll to the "Built in AUX" by pushing up or down on the Joggle. Now you can turn the function off or on by pressing to the right or left. Exit menu and Aux should be working.
Jan 12, 2010 | Kenwood eXcelon KDC-X559 CD Player
I need the manual for a Kenwood eXcelon KDC-X993
You can download the original user's manual from Kenwood website. Click on the link below and an online pdf will open in you browser window:
Be sure to have the free adobe pdf installed. You also right-click on the above link and select "save as" to save this online manual for further reading.
To visit Kenwood website for this receiver click here.
Oct 20, 2009 | Kenwood Excelon KDC-X990 CD/MP3/WMA/AAC...
I need the wires connector
ebay is a good place to search.
if that doesnt turn up 1 try any audio visual store or a kenwood approved retailer will be able to order 1 for you
May 20, 2009 | Kenwood Excelon KDC-X789 CD Player
I just bought a Kenwood KDC-MP438U I installed all the wires right, power is to the deck because it accepts a cd. the deck face doesn't light up. I called in at Kenwood and they had me test it directly to...
Check your Ground Wire inside the Truck and Check the Illumination Wire. I Think on Kenwood the Illumination Wire goes with the Power Wire. If they still will not work, You might want to get a Wiring Harness from Schoche.com Please Rate My Response! Thanks!
Jan 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Cd player locked
It has a defective ribbon cable between the face and the motherboard. This is a common repair, but must be done by a repair shop. My shop charges around $60-70 for parts and labor for that repair, to give you a ballpark of what to expect.
Sep 09, 2007 | Kenwood eXcelon KDC-X689
Car Audio & Video Logo
81 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
