DVD/CD-ROM driver does not not run any types of disc.
It says "DVD/CD-ROM drives not installed."
Device Status: "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click Troubleshoot to start the troubleshooter for this device."
When I checked the status in Device Manager, I found a little yellow question mark in front of the DVD/CD-ROM drives. Then, I uninstalled it, and tried to find a new hardware (just like what the instruction told me to do). It did find the new hardware, but it said something like ...the driver may be corrupted or missing.
Thank you,
Xu Ling
  • 1 more comment
  • peddy2520 Mar 26, 2008
    Dear Scorpionakku,
    Thanks for your answer, but I have no idea where I can find the OS to install. Should it be a Toshiba recovery and applications/ Drivers DVD that came with the laptop?
    My technical knowledge about computer is pretty low. I'm sorry. :-(
    Thank you,
  • peddy2520 Mar 27, 2008
    Thanks so much, Scorpionakku :)
  • blj432 Jan 01, 2009
    Master:
  • 351 Answers
Dear Xu Ling ,
Its O.S. related problem please try to install this drive on another Computer and i'm sure it will works perfectly. in this case you have to re-install the OS on your Existing Computer, if you wanna use it on your own PC.
Takecare
Posted on Mar 26, 2008
  • Akshay Choudhary Mar 26, 2008
    Dear Xu Ling ,
    yes you are right , Toshiba recovery and applications/ Drivers DVD that came with the laptop , but before re-install , my suggestion is ,you should have to backup your important data because after re-install there will be a fresh system in your Laptop.
    Cheerup and Be Smile always
  • Akshay Choudhary Mar 27, 2008
    Any time my dear friend.
    Be Happy always
SOURCE:
How to a record directly onto dvd using dazzle, when i install it only selects the hard drive as a place to record to. it has installed so as i can record directly to dvd but had my pc upgraded and had to...
Hi and Welcome to Fixyah,
Could you please checked your computer if you have your DVD writer.
Check here and do the procedure on how to checked it.
1. Click on Start
2. click Run
3. Type msinfo32 then click ok
4. System Information appears
5. click the "+" for components and see if you can find a DVD Rom drive listed. If you find one click on it.
6. Then click Edit and the Select All and the press CTRL+C 7. Go to your email reply and press CRTL+V to paste the information there.
It should look something like the info below.
Drive?D:
Description?CD-ROM Drive
Media Loaded?Yes
Media Type?CD-ROM
Name?TSSTcorp CD-R/RW SH-R522C
Manufacturer?(Standard CD-ROM drives)
Status?OK
Transfer Rate?Not Available
SCSI Target ID?0
PNP Device ID?IDE\CDROMTSSTCORP_CD-R/RW_SH-R522C_______________TS03____\5&19694FF7&0&0.0.0
Driver?c:\windows\system32\drivers\cdrom.sys (5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), 48.38 KB (49,536 bytes), 2
On select burner to you Instant DVD recorder program just click the pull down arrow and check the model of the writer and then click it and then hit prepared.
Regards.
Mar 17, 2010 | Pinnacle Dazzle DVD Recorder
My Cd-Rom doesnt work for my Acer Notebook 2930
Got to the Acer Web site and look under drivers and downloads. Select your model # and download the corresponding drive. Your prblem should be fix
May 15, 2009 | Acer Aspire 5100 Notebook
The DVD/CD drive on my Medion 8830 PC no longer burns
Have you changed or upgraded your OS recently?
Looks like the drivers are corrupt or out-dated.
Might go to your computer mfg support site or the Drive mfg support site and download the latest drivers.
Uninstall whatever drivers are loaded reboot and reinstall fresh copies.
Nov 21, 2009 | Computers & Internet
Disc Drive won't read after upgrade to Vista Ultimate
I had a disc Drive that wouldn't work for a while. There are a few things that could be wrong. The first thing I would try is to make sure it's pluged in all the way to both the Motherboard and the Disc Drive. Maybe it wasn't secure in there and when you bumped you computer just a little bit, it got unpluged. The wire connecting the Disc Drive to the Motherboard is probably your thinkest wire, can't miss it.
this next thing I would try is to delete the driver for your Disc Drive and then restart your computer. It should detect it automatically and have it running correctly.
If all else fails, go to Google. Type in the name of your Driver and search for an install that is supported on your operating system.
Jul 07, 2009 | Acer (4432A-002) CD-RW Burner
Did it give any error code, like Error code 39? And does the DVD/CD Drive appear in My Computer?
Normally the CD drives use the default Windows drivers. Try right clicking the HL-DT-ST DVDRAM GSA T50N ATA Device in Device Manager and choose uninstall. Then reboot the computer and Windows will find the device and re-install drivers automatically.
If you are still getting the error, it may be an update or some other program that added data to the DVD's driver data in the registry. Try this:
1) Close all open programs
2) Click on Start, Run, and type "regedit" (without the quotations) and press Enter. Back up (File > Export) the registry before you make any changes)
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • Left Click and Highlight: {4D36E965-E325-11CE-BFC1-08002BE10318} **Make sure you choose this exact key**
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed on the right hand side, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Mar 25, 2009 | Acer Aspire 2930-4661 Notebook
CD/DVD player doesn't read disc
Unless it's a hardware problem, (physically damaged, replace drive), then it sounds like a driver issue. Over time drivers (the software that runs the hardware) can be corrupted, get into a compatability conflict with new programs, or lost by the system. You obviously can't reinstall the drivers from your recovery discs, but you can (usually) download them from your manufacturer's website.
In your Start menu's search, type Device Manager. Open DM and expand the + next to DVD/CD-ROM drives.
If your drive is not listed in there, then it's not installed, download it's software from your manufacturer's website.
If your drive is listed but has a 9b861c0.gif next to it, then there's a driver problem. Double click the drive and note what it says under "Device Status" on the General tab. Go to the Driver tab and click "Update Driver..." Choose "Search automatically for updated driver software" and Windows will search both your computer and the internet for the proper drivers for your device.
Even if your drive is listed and it's status is "device is working properly" you may still need to reinstall the drivers. Often there can be a driver conflict that your computer is not aware of to report back. In any case, before replacing the drive you'll definately want to try fixing the drivers.
Hope this helps
Feb 26, 2009 | Toshiba Satellite U300-ST3091 Notebook
My SONY DVD RW ROM is not reading any DVD
Installing a third-party image editor or viewer applications may sometimes hijack the image file associations. In such circumstances, you could use this utility to repair the file associations (following image file types) to Windows XP defaults.
Click on Download utility and Click on RUN and then once again RUN
Check All the files and then click on Repair Associations
Download Utility
For the CD DVD Issue
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 12, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Cd drive showing instead cd-rw/dvd drive
Aug 02, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Sony DRU-500A Won't read DVDs... at all.
INSTALL VISTA ANY WAY the problem is that windows can use the drive..
BOOT OF THE VISTA DISC
enter setup when the system boots up
go to booting options
and select the dvd rom as the first boot device
ensure the vista disc is in the drive
and save and exir setup
it will tell you to pree any key to boot from cd/dvd
and it will install vista without any hassle
Dec 21, 2007 | Sony DRU 500A DVD±RW Burner
CD-ROM Driver Problem
CD-ROM error codes cdr101, cdr102, cdr103 Test the CD-ROM drive.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM
Installing a IDE/EIDE CD drive Ensure you have a working bootable floppy diskette with CD-ROM drivers.
Click on the above links, Follow instructions.
Should get ya back in/ Please dont for get to Vote.Thank you.
Dec 14, 2007 | Compaq Presario R3000 Notebook
Open Questions:
Computers & Internet Logo
467 people viewed this question
Ekse
Alun Cox
