Question about Kenmore HE2 Plus Front Load Washer
F28 code washer stops working. Reset will only
F28 code washer stops working. Reset will only work for a short time. Will replacing electic panel (expensive) fix the problem?
  • Anonymous Mar 13, 2014
    Stops working after a few minutes
  • Anonymous Mar 15, 2014
    The symbol F28 is flashing on washer, and washer not working...help
  • 5,081 Answers
Error code F28 indicates that one of the below part is bad
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on May 04, 2010
Testimonial: "I'll look for that manual-thx for the info"
  • Ricky Griffith
    Ricky Griffith Jan 26, 2014
    If the bottom front cover is pff it will also read f28
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F28 error code
I have a LG washer and dryer and mine get a PF code for power failure. I don't know if that's helpful or not. Contact the manufacturer for information on what the different codes mean. You can also look at the booklets that came with your machine. A lot of times, manufacturers will have the user manual online at their site.
Dec 10, 2013 | Kenmore Elite HE5t Washer
Thanks for your reply. I have a Whirlpool Duet Sport Front Loading Washer. I have an F28 Code. I removed the front panel below the door and pulled the tab to open the door (which was locked) and the...
F28 is a SERIAL COMMUNICATION ERROR.
If it's not just a bad connection not he Motor Control Board then the board will have to be replaced.
Aug 03, 2011 | Kitchen Ranges
Its flashing f28 and lock i have something in the washer also this is only my secind time using it i unpluged it and its still doin it
If your washer is a Kenmore The F28 error code on this model of washer indicates a communication error between the motor control unit and the computer circuit unit that results in the washer stopping during a cycle.
Read more: How to Unlock a Kenmore Washer HE2 Code F28 ' eHow.com http://www.ehow.com/how_7727221_unlock-washer-he2-code-f28.html#ixzz1GUHtruhM
Mar 13, 2011 | Washing Machines
Code 28
Error code F28 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below. In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    ERROR CODE F28
    Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
    Oct 05, 2009 | Whirlpool Washing Machines
    Washer starts fills w/water tumbles clothes for a few min. then stops and flashes f28.
    I took the top and bottom panels off the washer, followed the wiring and vacume lines, and found a small hole in the vacume line. I replaced the vacume hose and started washing. Everything is working great.
    Sep 18, 2008 | Kenmore Washing Machines
    Kenmore HE2 Plus Front Load Washer Logo
    3,125 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
