Piece of paper stuck in hp deskjet 940c - Office Equipment & Supplies
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Open the back cover and try the tp pull the paper slowly with two hands. Then take out the toner and make sure there are no papers there either. Be very careful to take all pieces of paper. Even a small piece left could cause great problems
Posted on May 04, 2010
Hp deskjet 940c does not print, blank paper goes thrugh. Computer conction is right, ink ok ( not flushing lights) and clean.
Hi you need a new black ink. it may be empty or faulty.
The machine dos not measure the amount of ink in the tank it only counts the amount of squirts you have used normally its only a problem with refiled inks
if this is useful please rate me thanks Ian
Mar 08, 2011 | HP DeskJet 940c InkJet Printer
Every picture I print has striations through them. My pictures all look like they have been printed on corduroy paper. I am using an HP deskjet 940c. Any ideas?
Hi
The printhead of your color cartridge is clogged
or is near to end
you need to replace the color cartridge or refill it (cheaper method)
check here how
Jan 19, 2011 | HP DeskJet 940c InkJet Printer
My HP deskjet 940c has been out of use for a while and I just started using it again. It now prints like have of a page, stops and continues the rest on another piece of paper. Why and how do I fix it?
put a single paper at a time when u give a printing command. also use good quality papers. Adjust the size of the tray.
i hope this would resolve the problem
Aug 02, 2010 | HP DeskJet 940c InkJet Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
My hpdeskjet 940c wont accept a 4X6 photo paper It tries but the paper doesn't slide through
Print a test page only in black. If little to no black shows, you need a black. If your color cartridge seems full, only get a new HP black ink cartridge.
Oct 03, 2009 | HP DeskJet 940c InkJet Printer
Pulls in multiple sheets of paper
you must not use thin paper. you should use thick paper so that it will only pull one paper at a time...
Apr 18, 2009 | HP DeskJet 940c InkJet Printer
HP Deskjet 940c keeps saying it's out of paper, won't print
I have the same problem. In the error message box is a Cancel button.
If I don't click the Cancel then the print goes through just fine and I click Cancel when the print is finished.
Sep 28, 2008 | HP DeskJet 940c InkJet Printer
Printer will not print
Paper is stuck in printer.I cannot free the paper which is stuck in the printer & I will need an expert to solve the problem.
Apr 28, 2008 | HP DeskJet 940c InkJet Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
k24674
jasbo
jasbo
