Question about Candy CDV262 Dryer
8kg Candy Condenser dryer keeps stopping and telling me the water compartment is full - trouble is , it isnt. is there a sensor that tends to stick on these models? Thanks, Andrew
Hi Andrew, Nothing I found on-line worked. So tonight I had a good look. Inside the machine at the back of where the water caddy fits there's a reservoir. This was full but oddly the water caddy was empty. On the caddy there's a spout with a valve, inside it was fine dark fluff which was being compressed every time the caddy was reinserted. I picked this out with a little stick. I also, and this may not be necessary, removed the valve socket that the caddy valve goes into. It's attached by three screws to the bottom of the machine. This was also clogged with the same sort of fluff. Both blockages were stopping water passing freely into the caddy and so water built up in the reservoir tripping the empty light. Something to check for. Anyway mine works fine now and thought I'd share. Best regards, Ed
Posted on May 13, 2010
  • Paul Brookes Dec 05, 2012
    Hi have just received new timer switch for my candy cic60 condenser tumble dryer but the wire wire connectors are different to the new one letter coceds and any numbers on them for each wire connector are different i have its an updated switch i need some sort of wiring diagram for the switch
Can anyone tell me where I can get a capacitor for my Candy Condenser dryer model GOC218-80
http://www.buy-spares.ie/candy/tumble-dryer/catalogue.pl?shop=candy&path=111515
Jun 30, 2015 | Candy Dryers
The water light full light keeps coming on and the tumble dryer it stops working but the container has very little water in. it's a Candy GOC580C
SOUNDS LIKE A BAD MOISTER SENSOR USUALLY LOCATED INSIDE THE DOOR PANEL AT BOTTOM, LOOKS LIKE 1 LONG LITTLE SILVER THINGYS
Dec 17, 2014 | Candy Dryers
It says the water needs emptying but it is empty
After reading about various dryer problems / solutions it seems others have had this same problem. It could be that a smaller resevoir which houses the sensor connected to the water collector is full and it's valve may be blocked with lint. It can be solved by getting to the valve and removing the lint. You may need to remove the valve itself. Hope that helps. Good luck.
Oct 20, 2012 | Candy CDC266 Dryer
Bosch classixx tumble dryer container full light keeps coming on which is stopping the cycle but container is empty
This is happening me too. Have you had any suggestions how to solve this problem???
Nov 16, 2009 | Bosch Dryers
I have a candy cic60 reverse action condenser dryer about six years old.when it is switched on i makes a buzzing noise and nothing happens apart from the buzzing,any ideas
my candy dryer when on the light keeps come on to clean fliter and the water contain dont seem to being filling up with water
Jul 07, 2009 | Candy CDC266 Dryer
Candy Easy logic Condenser.
You haven't mentioned emptying the water tray at the bottom if you have you replaced it properly?
Nov 04, 2017 | Candy CDC266 Dryer
Candy cic60 01 condenser dryer
check the vent line it may be cloged or bent if this is good then possibly the hi temp sensor may be bad ?
Nov 15, 2007 | Candy CDC266 Dryer
Candy CDV262 Dryer Logo
1,178 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Candy Dryer Expert? Answer questions, earn points and help others
