My sandisk cruzer is not working i think i damaged the connection as the blue light only comes on when i am sliding it into the usb port and then disapears. the computer says it does not recognize the device. This is happening on multiple computers. It was sorking ok yesterday or this morning now it is dead
    Master:
  • 351 Answers
Dear NVCAP ,
Please contact to Authorised dealer of SANDISK . it seems that your Sandisk drive had main PCB Problem , and just request to dealer ,if he can arrange you to recover your data.
Takecare
Posted on Mar 26, 2008
SOURCE:
How to insert sandisk cruzer force usb flash drive into computer?
Usb sockets are all same. Haven't changed. There are other sockets that look similar. HDMI, eSata, display port. I would look very closely to make sure you are attempting to install in the correct port. You might first want to take a look at the flash drive end to make sure that there is no damage. Shouldn't be unless you really tried to force it into wrong port. Other than that, it will fit.
Aug 02, 2014 | SanDisk Cruzer Force 16gb Usb 2.0 Flash...
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
I simply do not know where the sandisk cruzer 4 GB is suppose to be inserted. I tried a USB 2.0 connector, but the sandisk does not fit.
The sandisck cruzer fits in any standard USB port. Make sure there is nothing jammed in the USB port or that the cruzer's socket is not damaged - (Like if the metal is bent or our of shape.)
Jan 10, 2011 | Computers & Internet
Unable to open the files no led light comes on on my Titanium Cruzer 8Gb Flash drive
Try to read the drive in different USB ports - or different computer entirely to see if the problem is limited to a particular USB port or computer. If the the problem follows the drive, there is likely a problem with the drive itself. You should also try to gently push up, down, left & right on the drive while it is connected to the USB port. The thinking is that if there is a damaged connection in the drive, you might be able to complete the circuit while pressing in different directions. If you can get the drive to light up - you should try to copy all files from the drive while pressing on the drive in the direction that keeps it lit - until all files are copied. Once completely copied, the drive should be discarded as it is no longer reliable, unless of course, it is still under warranty.
Oct 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My usb sandisk 4gb cruzer micro has ' not recognize ' and my usb port is working well.
Try on other computers with a Windows 7 or linux. If not working on other computers as well, the drive is damaged.
Aug 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I inserted my new usb 2.0 sandisk cruzer flash drive and it does not work..
Does the activity light come on? Have you tried it in a different USB port? Also try using it in another computer.
Nov 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 2GB cruzer micro USB not detecting
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect sandisk to computer then cehck if still face problem try all usb port of computer.
Aslo check your usb port of computer are working fine.
Aug 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer no longer recognizes sandisk when inserted into USB port
Dear, it is out of order thats why there is problem, don't attach it otherwise it will cause more problems, it gets hot due to the circuit shot. So, visit the repair shop for better solution.
Best regards.
May 27, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer 8 gb micro usb not being recognized
Do you have another USB port you can use? Is this connected to a USB hub?
Jul 26, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Open Questions:
Computers & Internet Logo
51 people viewed this question
Ekse
Alun Cox
