Question about Microsoft Xbox 360 Console
I have my xbox and computer connected with a ethernet cable and when i test the connection its says not connected
    Problem Solver:
  • 5 Answers
Make sure that on your router, whichever port is connected to the exbox the corresponding light on the front is lit up. Also you need to make sure that you are using a CAT5E Patch cable from the router and not a pc-to-pc networking crossover cable.
If there is no light corresponding to the port you have connected to then there is either a bad connection or you have the wrong cable
Posted on May 04, 2010
How to Get Better Connection on Xbox?
    -Find router and Xbox
    -Navigate to My Xbox utility and select System settings from menu
    -Test connection when prompted
    -Check location of modem
    -Relocate devices
    -Disconnect other internet capable devices
    -Disconnect 3rd party headsets
    -Move electronics away
    -Obtain Ethernet cable
    -Plug one end of Ethernet cable into Xbox
    -Plug other end into router
    -Restart both devices
    -Turn on Xbox
Oct 20, 2016 | Video Game Consoles & Games
How do i join and set up xbox live from my laptop to my xbox360 console using a ethernet cable/help
1) Connect your ethernet cable to your computer and xbox
2) On your PC, Go to network connections and right click on your wireless connection
3) Click the advanced tab on top
4) Go to Internet connection sharing and check the box, click OK
5) On your xbox, Go to your network settings
6) Edit settings and set everything to automatic
7) Test Connection
You must have your PC on at all times to connect to Xbox live this way.
If this setup doesnt work.
1) Go to Network connections
2) Select both your wireless connection and your LAN connection
3) Right click and bridge the connections
4) Same setup on Xbox as the previous instructions
5) Test Connection.
Apr 29, 2011 | Microsoft Xbox 360 Console
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
    Please try the following steps below;
    To make a router connection to Xbox LIVE:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console and sign in with your profile.
    8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
    If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
    Hope this helps!
    Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
    Xbox 360 cannot connect to the internet with a new cable
    Go to your my xbox page, scroll all the way to the right to the system settings page, click on network settings, test xbox live connection, this will tell you where your problem is and also give you suggestions on what to try, if you still cannot get on comment, we may be able to help.
    Remember thumbs up if this helps.
    Feb 07, 2010 | Microsoft Xbox 360 Console
    How to hook your xbox360 to laptop to get on xbox live
    wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
    Oct 25, 2009 | Microsoft Xbox 360 Console
    Nat Is Moderate Xbox Live
    So let me get this straight; you have your XBox plugged in, via ethernet, to the modem, and are testing the connection?
    Jun 15, 2009 | Microsoft Xbox 360 Console
    Can't connect to Xbox 360
    reset it...look at back side of modem.....
    and if it not works then contact your isp ...
    Aug 18, 2017 | 2wire HomePortal 1100 Router...
    Can't connect with network
    if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
    if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
    by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
    glad i could help!!! :3
    Feb 06, 2009 | Microsoft Xbox 360 Controller
    Xbox 360 to wireless laptop
    Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
    Mar 16, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
