I need the wiring diagram for my Intertherm central electric furnace, model number FEH-015 HA with central a/c. I am having relay problems and thermostat wiring problems after my fan motor had to be replaced. Thanks!
  • 49 Answers
SOURCE: Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Posted on Oct 14, 2007
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
  • 659 Answers
SOURCE: i have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Posted on Mar 17, 2009
SOURCE: I need a wiring diagram
I need a wiring diagram for an intertherm/nordyne gas furnase !!!
Posted on May 26, 2009
flatech
  • 111 Answers
SOURCE: I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE
Best things to do is find your Return grill in the home.
Get a measuring tape and measure the Hole size with the grill removed, Or filterback grill whatever the case.
Then simply go to a home retailer with the size, or in rare cases you may want to consider a Hogs hair washable filter that can be cut to size, to fit it perfectly.
Posted on Oct 24, 2009
I have a 1987 Intertherm FEH-015HA electric furnace. The issue I am having is that my blower will not shut of unless I pull the disconnect. My thermostat will operate the heating elements like normal,
You most likely have a bad fan limit / cycling switch. If you kill the power to the furnace see if you can trace the wires from the motor to where the connect to the switch. It looks like a round button with tabs sticking out of it for the wires to connect. Mark down where the wires were connected and take it to a HVAC business or furnace supply house. Be sure to have the model off the furnace with you so you can get the correct parts.
Nov 25, 2014 | Intertherm Heating & Cooling
How do you hook up the thermostat to a Central Electric feh-017ha-04 furnace? Also, where do the A/C wires hook up to the furnace?
The standard color code for the HVAC is as follows....
Red=Hot or 24v
White=Heat
Green=Fan
Yellow=A/C
White 1=secondary heat.
Blue=Spare
Orange=Heat Pump
C=Common
The thermostat has the terminals marked R,Rh,W,G,Y.
The furnace should have a terminal strip with similar markings.
If you only have 1 control transformer this will be easy.
Hook the wires up using the colors I have listed. If you don't have the same color wires go with whats close to them....such as use Orange for Red etc. It really doesn't matter as long as they are landed on the same terminals on the thermostat and furnace. Two wires running to A.C unit outside put one on Y the other on C. If you need any more help let me know!
Jun 02, 2014 | Intertherm Heating & Cooling
Have 84 model feh-015ha heater comes on but motor wont start
should come on with first stage heat bad sequencer or motor.
Jan 30, 2014 | Intertherm E3EB010H Electric Furnac
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Disconnect assembly has overheated and needs replacement. where can I find a new puul-out disconnect assembly for my intertherm furnace model FEH-015HA-03
Those parts are readily available. You can get them at intertherm.com or google hvacparts.com and have your model and serial number ready. You are talking about the pullout at the bottom left of the unit correct. If you have a breaker within six feet of the pullout you can remove it. But be very careful and turn off all power before you try.Rus
Dec 04, 2009 | Heating & Cooling
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
I have a intertherm model feh-017h electric
Mar 17, 2009 | Heating & Cooling
Blower will not shut off on furnace. I have a Intertherm FEH-015HA Central Electric Furnace
If your blower will not shut off from the thermostat, you either have a bad thermostat or your red and green thermostat wires are exposed to each other.
Feb 20, 2009 | Heating & Cooling
Heating & Cooling Logo
330 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
