Question about E-Machines eMachines Desktop PC
Add in slots
How do you remove the fillers to add cards?
  • 185 Answers
If you are talking about pci cards and all of that you have to open the computer from the side removing the screws on the back and sliding the cover towards the back of the CPU. After you remove the side, check the filler you want to remove and there is just 1 screw that holds each one of them, remove that screw and pull the filler out. that opens the bay for you to install a modem, pci card etc.
if it works for you don't forget to rate me
thx
Posted on May 04, 2010
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
https://www.greatcall.com/docs/default-source/pdfs/jitterbug-smart-user-guide.pdf
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
May 19, 2017 | Cell Phones
Can I replace the video card or add a video card to my laptop Gateway MX3225 Notebook for a better one?
Video cards are normally built-in on the laptop motherboard and you cannot replace them or add a new one because there is not an expansion slot to add a video card.
Aug 12, 2012 | Gateway MX3225 Notebook
Where can i buy a onchip usb2?
FIC FR33E motherboard?
http://www.ebay.com/itm/FIC-FR33E-L-MOTHERBOARD-CPU-LOT-10-/170633274365
Reference: Photo
To the far left side of the motherboard, is actually the Bottom of the motherboard, when installed in your computer case.
The two White long expansion slots you see, are PCI expansion slots.
If one is available, (Open), you can use a PCI USB adapter card.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Seem cheap? Nope. Good quality also. (You can also check the reviews)
Need guidance in installing?
1) Follow Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside the computer.
Computer on a table, computer unplugged from power, computer case open.
[Note* Always unplug the power to a computer AT the surge protector. NOT at the back of the computer. (Power Supply)
You can cause a power surge ]
2) TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
3) Finding an open PCI slot look at the back of the computer. In the metal frame you will see slots going horizontally.
These are Expansion Slots.
You may have an add-on adapter card already installed, in one of the PCI slots.
The expansion slot cover for it is removed.
You should see expansion slot covers however, in the remaining expansion slots on the back of the computer metal framework.
Remove the one that corresponds with the PCI slot you wish to use.
Be aware that the PCI slot will not be directly in line, with the expansion slot.
When installing an add-on adapter card, you will see when the card is inserted in the PCI slot, the metal bracket on the add-on card, lines up with an adjacent expansion slot.
This will make more sense to you once you go to install the card.
[PCI USB adapter card is an add-on adapter card ]
Line the card up in the PCI slot. Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Also, at the same time line up the metal bracket of the PCI USB adapter card, with the metal framework of the computer case at the back.
Gently push the PCI USB adapter card down into the PCI slot.
Fasten the card's metal bracket to the computer's metal framework.
Post the computer manufacturer name, and model number, if you need guidance in opening the computer case. Post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | FIC Computers & Internet
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
I have a dell dimension 3000. I want to add a 2nd monitor. I believe the video is integrated, Does the unit have a slot to add a video card. What kind of card should be added?
The Dimension 3000 Springdale G chipset supports AGP 8X cards, integrated video, integrated audio, ICH5, 533/800 MHz FSB, dual channel DDR 333/400 memory, integrated Serial ATA, and the Intel Pentium 4 Prescott.
The AGP 8X slot refers to Advanced Graphics Port. You can add a AGP video card if you motherboard has that slot. Usually that slot is encased by a green plastic enclosure .
Aug 02, 2011 | Dell Dimension 3000 PC Desktop
I have a sony Vaio VGN-FE38GP, the graphics card has died. I have googled a bit and understand that graphics card is embedded into motherboard. So should I change the motherboard? What motherboard...
if the embedded graphics card have problem you can contact a chip level engineer to repair them or you can use an add on graphics card buy a add on graphics card for the pci express remove the covers and find the pci express slot and press the card into the slot screw the end to the cabin then switch on the computer and you display will be ready
Feb 17, 2011 | Sony A-1273-689-A - VAIO VGN-FZ Series...
I have a tracphone and i want to put that sims card in that motorola phone
The sim card slot is located under the battery. You have to remove the battery cover and remove the battery to find the sim card slot. Next to it there is a micro sd slot if you want to add extra memory to your phone.
NP
Jan 10, 2011 | Motorola Mobility ROKR E6 Smartphone
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
Want to add video graphics card-which one suits?
Buy any nvidia card of your price range. That should be pci express. There will be a slot on your motherboard. you have to add the card on most probably Grey color slot, biggest slot from the others.
All done. Then setup the driver from cd and enjoy.
Ask here if you want to know something more.
May 21, 2009 | Computers & Internet
AGP
You can add an AGP Graphics card if an AGP slot (Not White) is provided on the motherboard not a connector just to clarify.
Dec 01, 2007 | AOpen ADD Card AGP Graphic Card
E-Machines eMachines Desktop PC Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
