Question about Mitsubishi HC100 DLP Projector
Comes on and turns off before bulb gets warmed up
  • slashin24 May 04, 2010
    thanks for your good advice. the bulb actually comes on for about 10 seconds when it switches to video it turns off. fans are good and bulb is 5 months old. do you think it is a connection issue or possibly a ballast issue? bulb lights but shuts off.
    where or who would you recommend for send out repair?
    thanks for all your help. i think its a power issue also
    President:
  • 2,923 Answers
First, re-seat the lamp. Remove it then put it back in. Make sure that the lamp is properly installed.
Be sure also to tighten the lamp cover. It that did not help, check the exhaust of the projector and be sure that the air is properly circulating. It the projector is dirty, that might cause the overheating from inside, and shuts the projector off.
Posted on May 04, 2010
  • Melvin Ramos
    Melvin Ramos May 04, 2010
    Thank you!
    I think it's the ballast and/or power issue. Once you turn the projector on, initially, it's not getting too much power from the power supply, and the internal components (such as capacitors and resistors).
    Once it switches to the video, the projector will suddenly require a big amount of power. If the capacitors cannot provide the require power, it will cause the projector to shut down, and resistors might become busted.
    You may try checking it, and see if there are any swollen capacitors. It's okay if you have basic electronic background, and if the projector is out of the warranty.
    However, if you're not sure what to check, I would suggest to contact a pro and have him repair it for you.
    Thank you!
  • Melvin Ramos
    You may check the link below:
    http://www.projectorlampexperts.com/
    The name of the company is "Projector Lamp Experts", but they're actually expert in any kinds of projector problems.
    Thank you!
How to change the light bulb in a maytag 8114P732-60 oven
Hi Mary. I had a bad bulb in my Maytag new from the factory. I also had a hard time getting the glass lense cover off, and didn't want to be too rough with it for fear of breaking it. But it WILL come off if you turn it hard enough. I've since seen suggestions about putting warm water on it to loosen it up. And another person wrote and said using an oil filter wrench on it worked like a charm.
Good luck
Jul 27, 2014 | Maytag CWG3100A Gas Single Oven
I have a 3M 1700 Overhead Projector. After about two months of use, my bulb stopped working, so I replaced it with a new bulb. When I turned on the projector, there was a slight "pop" and the...
Take the lamp out and check for physical damage. Some lamps come defective and can shad (brake glass inside) upon warming up. The "pop" sound could be it.
Feb 12, 2011 | Office Equipment & Supplies
Makes viabration noise when blubs installed and blub start flickering. it is six year old Whirlpool gold & just startered happing
It sounds like the bulb is not making good contact with the socket. Try this.
- Unplug the refrigerator.
- Take a blow dryer and heat up the socket where the bulb screws in. Do this for about 1 minute only, be careful not to over heat the plastic side walls so direct the heat on the socket to make sure nothing else gets too warm.
- Retighten the bulb into the socket, this warming will allow the bulb to seat better and tighten up more.
- You can use this same technique when you need to remove a bulb, a warmer socket will let the bulb come out and go in easier.
Apr 18, 2010 | Whirlpool Refrigerators
Freezer freezeing but rifridgerater warm
change the control board, it gets bad from blowing out light bulbs,if you've had to replace bulbs and they don't come on and they buzz when replacing its definately the board part#4334000 appliance parts pros 1-877-477-7278
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
RCA SCENIUM MODEL D44LPW134 IS MY BULB BLOWN?
If this is a DLP, which I believe it is, your bulb is blown. Look for an indicator light on the front of the tv. After you hear the bulb try to warm up two or three times the indicator light should come on and stay on steady.
I own a 57" Mitsubishi DLP and have replaced the bulb three times now. It was the latest and greatest technology when I bought it, but knowing what I know, I dont think I would buy another DLP.
By the way, get the bulb number then check ebay, by far the best prices.
Jun 02, 2009 | RCA Scenium HD50LPW52 Replacement Lamp
Hello, Greetings from Hamilton Ohio. I have a 54 inch Hitachi rear projection television and I believe the bulb is getting ready to go because it takes about four or five minutes before the picture comes...
Hello
And greetings from York PA!
Ok I have read what you were saying about your TV and after much consideration I dont think its the bulb because a bulb does not get better as it warms up! (most bulbs that are bad get worse as the TV warms up!) But capaciters do act this way when they go bad (stable when they warm up!) so I would have to say the control circut has one or more bad capiciters on it and will need replaced!
I hope this helps greatly!
Please rate this answer!
thank you!
Jan 27, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
Scanner bulb warm up
I have the same problem and it seems that the only way to fix this is to replace the scanner bulb. The problem is that, as far as I can tell, the bulb comes as part of the scanner assembly - and so you have to replace the whole scanner assembly. It is quite expensive - 200 to 300 dollars Canadian. There are whole machines available for $300.00 though so is it worth repairing if one cannot just buy the bulb? Ger.
Jul 13, 2008 | HP LaserJet 3330MFP All-In-One Printer
Warming up
Hi, The warming Up messge usually occures when the scanner bulb is not getting heat up for the correct temprature or the scanne bulb might be defective.. To resolve this issue follow the below instructions.. First connect the printr directly to a wall outlet as some times surge protectors will not provide the required power for the printer then this message can come up. Once the printer is directly connected to the wall outlet try to turn on the printer and check with the issue.. If the issue presists try the instructions in the below webpage.. http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&lc=en&dlc=en&dlc=en&lang=en This shoule resolve the issue .. Wish u success.. Regards. Barret.
Oct 01, 2007 | HP PSC 2175 All-In-One InkJet Printer
Mitsubishi HC100 DLP Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
