Question about Troy-Bilt Pony Garden Tiller
ReplacingTINE SEALS AND GASKETS
I have replaced the left side(as you are behind the tiller) gasket and seal and it appears to be leaking from the other side.I can not get the tines off is it different on the other side I took the bolt out that holds the tines to the shaft but it will not budge is the other side different?
  • 12,061 Answers
Http://www.motorbookguy.com/Rotary_Tiller_Repair_Service_Manual_Third_Editio_p/cl-rts3.htm
Repair manual above... http://www.partsandservice.com/html/TroyBilt/ti/
http://www.troybilt.com//
Below, exploded diagrams..
http://www.partstree.com/parts/?lc=troy_bilt&mn=5150+PONY+V+5HP+ELEC+(S/N+S186072-S0204132)&dn=0056000008
http://www.partsandservice.com/html/TroyBilt/ti/tihorse.html
OK these links above should be able to help you there are exploded diagrams of parts etc, Really you need a Service/Repair manual, for your exact make model. Anyway hopefully, these links will give you the idea of what to look for.
Posted on May 04, 2010
Model #79575543401 KENMORE ELITE Refrigerator The left side double door leaks at the bottom into the interior of the fridge. There is a panel on the inside of the bottom of the door, but not sure how...
. Using a good light , flashlight , etc. check your refrigerator and freezer door seals . This is the gasket that seals the door shut when closed . Look for cracks, tears, and possibly bumps in the gasket material. If you notice any of these , replace the door seal gasket . Furthermore , it is always best to replace both door gaskets at same time .
Feb 19, 2011 | Refrigerators
I have a 1986 yamaha 540 srv snomombile and when i throtle it up it bogs out and pops like a backfire do you have a suggestion on what is causing this and how to correct it?
You should purchase a gasket and seal set, pull your motor out of the sled, disassemble the motor, and replace all the gaskets and seals. You can purchase a piston kit on line that should come with pistons , rings , gaskets , and seals.The main problem you are having is an air leak on one or both of the crank end seals. Usually the clutch side seal leaks first. If you continue to drive you will probably score one or both of the cylinders.When you have the motor apart clean your carburetors and replace your spark plug caps. NGK has new plug caps for about $5 each. If your cylinders look good i would consider doing a light hone job and ring replacement. Again if you just buy new aftermarket seals pistons and gaskets you should be able to do a complete rebuild for about $150. Then your engine will be good for another 25 years. If you are limited on funds Just replace the crank seals , clean the carburetors, and put on new NGK plug caps (about $30).
Jan 18, 2011 | Yamaha SR 400 Motorcycles
Trying to track down oil leak need cutaway to help find possible locations on engine that could leak motor oil
Best is to pressure wash it - then run and inspect it after the run.
If it's at gearbox join - suspect main crank seal
If it's near oil filter - replace gaskets there.
If near cambelt - expect to replace seals behind there.
Or head gasket.
Dec 27, 2010 | Ford Escort Cars & Trucks
Hay i got a 1997 dodge intrepid and on the driver side the bk spark plug i went to pull it out and when i got it out my spark plug and scocke was coveger in oil do u no why and how to fix it
Sparkplug tube seals are leaking. You will need to remove the valve covers and replace the valve cover gaskets and the round seals in the middle of the cover. the tube seals should come with valve cover gaskets.
Nov 20, 2010 | 1997 Dodge Intrepid
2002 Passat, 30 valve V6 has oil leaking on exhaust manifold. VW dealer says its the cam adjuster seals. It looks to me like its just the valve cover gaskets but I can't get an engine schematic to see the...
I have a 2000 Passat V6. They told me that same thing. To replace the gaskets is easy. You just remove the covers and the air filter box and unscrew the 6 bolts holding the valve cover on it and there you go. You want to clean around the gasket service and add a little bit of sealant to the edges. Replace the old gaskets and put everything back together, be careful not to overtighten the bolts, can flatten out the gasket and cause oil leak again. On the right side of the engine, you have to remove the coolant box to get to it. Same procedure....
Oct 18, 2010 | 2002 Volkswagen Passat
Water leaks out on the floor from the front left of the machine, not every time though. what's the most likely place to check? intake hose? drain hose? door edge?
Hello there:
If your dishwasher leaks, check these: Main tub seal Note... If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. Lower rack Spray arm Spray arm support
Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Sep 26, 2010 | Maytag PDB3600A Built-in Dishwasher
Ford mondeo 1.8 td diesel, the problem is the power steering fluid is leaking, when i check it look like it was coming from the middle part of the radiator.how can i fix it and what parts do i need to get...
Have a look at the power steering fluid cooler it is just in front of the radiator behind the front bumper. The coolers corrode and leak. Also the seals can go, check for fluid leaking out of the boots at the track rods. Try this procedure :--- 1)Trace the source of the leak. Use a mirror on an extended handle to follow the puddle of fluid on your garage floor to the power steering system. Look on the hoses and gaskets to find from where the fluid could be leaking. 2) Add power steering stop leak additive to your power steering fluid. Lucas Power Steering Stop Additive is 100 percent guaranteed to stop seal leaks. In older cars, the seals shrink, causing leaks. The stop leak makes the seals swell to their original size. 3) Use gasket sealant if the gaskets are old and leaking. Sealant, such as Permatex, is resistant to engine fluids, and will help repair a leaky gasket. 4) Replace the gasket, if the gasket sealant does not work. Thanks. you can rate this solution and show your appreciation.
May 19, 2010 | Ford LTD Cars & Trucks
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking problem from the door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
May 03, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
Troy-Bilt Pony Garden Tiller Logo
70 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
