Question about Dishwashers
Maytag MDBF750AWZ, Quiet Series 200 - sticking, stiff door handle
My Maytag Model MDBF750AWZ, Quiet Series 200 has a door handle that has become stiff and sticks and am having difficulty releasing the latch to allow the door to open. How can I clean and lubricate this part of the washer? thanks!
  • 901 Answers
There are lot of handy sprays available. Try your super market or the hard ware stores where plumbing materials or sold.
Posted on May 04, 2010
Maytag Quiet series broken?
Check the door switch.
May 03, 2013 | Dishwashers
I have a maytag quiet series 200 thats only 3 yrs old and now it cleans great it just leaves water in the bottom, it seem its not pumping out the water..
Is this a front loader? If so, there is a panel right below the door. Three screws hold the panel. Remove the screws, and right behind that panel is a filter. have a towel ready, and screw the filter out. it is probably clogged. Remove the debris from the basket, was it out and replace.
If its a top loader, then try running about a galleon of vinager thru it to remove the hard water build up. Good luck
Nov 14, 2012 | Maytag Dishwashers
I have a maytag quiet series 200 type 777-0 when i push the start/cancle it will not start?
We had the same issue with our Maytag quiet series 200 dishwasher. The Start/cancel button would not work all the time. We ended up removing the front panel from the machine and on the backside of the panel there is a plastic ultra thin ribbon cable that runs from the computer box to the push button control panel. We wiggled the ribbon cable and the start button began to work, but only if the ribbon cable was held in a certain position. So we super glued the cable in that position and it's been working consistently now.
Upon closer inspection the ribbon cable appeared to have 3 or 4 very tiny dark spots on the wires.
That would indicate to me that somehow moisture slowly eroded the tiny wires and bending the cable made the connections touch again, but for how long it will work like this is anyone's guess.
Also, it appears that the ribbon cable is permanently attached to the push button control panel. So you can't replace the ribbon cable itself without buying the hole front panel.
Aug 19, 2010 | Maytag Dishwashers
Maytag built in dishwasher quiet series 200. Door closed and latch won't release to open door.
insert flat head screwdriver in side of handle and pry out or use dinner knife(butter knife)
Aug 13, 2010 | Dishwashers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
How do I replace the latch on my maytag quiet series 100 dishwasher?
Unfortunately, the Maytag quiet series models have plastic latch handles that are prone to crack after time.
You should be able to order a replacement handle through a distribtor.
If you can, unlatch/open the door. Using a star screwdriver, unscrew all the screws on the inside of the door frame.
Once all the screws are removed you should be able to separate the inside of the door from the latch assembly.
From there you'll need to squeeze the latch handle together and replace it in. I'll warn you that it feels like you have to squeeze the thing so hard you might break/crack it on your own. It is a hard/tight fit if I remember correctly.
One last thing you may want to do to is check the food grinder in the middle of the washer. Sometimes the cracked pieces of the latch can end up there stuck in the grinder causing it to be louder than it should.
Hope this helped.
Nov 06, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 200 Handle Broken
Remove the torx screws around the inside of the door and pop off the inside cover. Remove two screws and unplug handle. Remove broken handle. Insert new handle and replace screws.
Sep 20, 2009 | Dishwashers
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Maytag Dishwasher Latch Sticks
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
Dec 20, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
1,272 people viewed this question
Top Dishwashers Experts
