Question about RCA CDRW120 2-Disc CD Recorder
I am tring to burn songs from a cassette tape to a cd and i have tried both cd-r and cd-rw and neither one of them are working.It says unreadable disk!What do i do?
    Brigadier General:
  • 8,546 Answers
Try using CDR-Audio or CD-R Music discs. If you don't have the manual try retrevo.com
Posted on May 03, 2010
CANT TRANSFER CASSETT TO CD
Hi Margaret,
You can download the manual for this device here. The downloaded file is called "ad-rw900.pdf" and should be found in your download directory.
Locate and open the file (Adobe Reader) and review page 31. Here you'll find the details to go about recording a CD from the source you've selected with the "Input Select" button. When recording to a CD-R or CD-RW with a cassette TAPE (or LINE IN or PHONO) as the source, you must manually set the recording level as directed in step 5 on page 32. Check the blank recording media. The device is ONLY capable of recording on "CD-R" and rewritable "CD-RW" blanks (these are very different from DVDs of any type). The CD-R type will likely enjoy wider compatibility (than CD-RW types) when played back on a different (car or other) CD player.
I hope this helps & good luck!
Dec 16, 2013 | Teac AD-RW900 CD Recorder and Auto Reverse...
How to burn another song?when i try it say insert a blank cd??im using cd-rw..then i try to delete some song it still on the list.. :( why??
Some where in the process there's an option called leave the session open. This tells the cd file system to allow more songs or data to be added later.
If not as you burn a track it makes the the cd read only hence the put in another blank cd even though there's plenty of room on cd and that your using cd rw
Dec 20, 2012 | Computers & Internet
How to burn a Cd
The Sony MHC-BX2 can record from a CD to a cassette tape. This model doesn't have a CD burner. The manual for the MHC-BX2 is available from Sony support: http://esupport.sony.com/US/p/model-home.pl?mdl=MHCBX2&template_id=1&region_id=1&tab=manuals#/manualsTab . See page 12 of the PDF.
If your unit is a different model, please post a comment with that model number. I wish that I had better news for you.
(on those shelf systems that can burn a CD, place a blank CD-R or CD-RW (if supported) in the disc tray. Use the function button to set the recording source (Phono with the Croseley units). Place the tape to record in the tape deck and press play reach a point a bit before the desired point to start the recording. (Some also will record from the radio, turntable, or other device. Again start the source playing.) Then press CD Record. Press Stop when you want the recording to stop or when one side of the tape/LP is finished. (Some have a Split Track button if you want to identify every track. Press this during the silent period between songs.) Otherwise, you will get one track per side with tapes/LPs.)
Jul 10, 2012 | Sony Audio Players & Recorders
RCA RS2603 digital audio system stopped playing CD's. Double cassette tape deck works as does radio, but cannot play CDs.
chack and see what type of CD you are using. i have been having the same issue. i actually found out that the CD's i use to play songs, and etc are "CD-R". the compatible CD's for my (RCA DIGITAL AUDIO SYSTEM RS2603) sterio are CD-RW's or compact disc that you find on production music like albums, etc. hope this helped !
Jan 03, 2011 | RCA RS2046 Shelf System
I am trying to burn a cd on my Acer Aspire 5536-5255 using WMP and it isn't working?
In Windows Media Player, click Library and then, in the List pane, click <List Name> List, and then click Burn List, as shown in the following screen shot.
  1. If you need to clear the list before beginning, click Burn List, and then click Clear List.
  2. Drag a folder from the Contents pane or songs from the Details pane to the List pane to create a list of songs to burn.
  3. In the burn list, drag songs up or down to arrange them in the order you want them to appear on the CD.
  4. Insert a blank CD-R or CD-RW disc in the CD drive.
  5. In the List pane, verify that the songs you have selected to burn will all fit on the disc. If necessary, remove songs from the list by right-clicking a song and then clicking Remove from List, as shown in the following screen shot.
It is possible that a song will not fit even if the total time exactly matches the CD length, because the Player inserts two seconds between songs when burning. Click the Start Burn arrow and verify that Audio CD is selected, as shown in the following screen shot.
lick Start Burn.As the CD is burned, you can check its progress in the burn list. Burning a CD will take some time.Notes It is recommended that you do not try to perform any other actions while burning a CD. For example, playback may be affected if you try to play a music CD while burning a CD.
You cannot burn additional files to a CD after burning is completed. If you are using a CD-RW, you can erase the entire CD before using the Player to burn files to the CD again.
Nov 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have been attempting to burn a cd from my itunes library, it keeps giving me an error 2630. Yes I am using a new blank cd.
What type of CD media does your burner support? CD+R CD-R, CD-RW.
A few suggestions:
CD-RW or re-writables do not support audio burning to CD format.
Are songs being burned as a data disc(unplayable files) or CD audio?
Have you exceeded the 700 to 800 MB range of data that a CD can hold?
Try dropping a couple of songs off the list and see what happens.
Try rebooting the computer and try burning again.
Down load a free version of Nero software and try to burn the CD from there.
Oct 13, 2009 | HP HewlettPackard Pavilion ZE5400 series:...
Converting cassette tapes to CD's
we can convernt cassette to CD in the PC with good sound card I am using creative sould blaster or audio gy it is not expensive hardly in indian currence of Rs.18oo/- you can purchase from any computer shop. or go to creative site and see models.
Sep 04, 2008 | Audio Players & Recorders
Copying
Whats the model Drive ?
and most of the time to transfer audio tapes or records to cd, Connect it to your line in in the computer, record the audio on the computer and then burn it to cd.
I know that wasnt what u asked but u didnt specify the drive you have so i just tossed the above in just incase ... regards
Dec 28, 2007 | Pioneer DVR-S111B DVD RW Dual Layer Burner
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
RCA CDRW120 2-Disc CD Recorder Logo
59 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
