Question about Insignia IS-LCDTV32 32 in. Television
I only get sound in DVD mode. No volume at all in TV mode. What should i do?
    Scholar:
  • 70 Answers
Your tuner may have lost the audio signal and need to be replaced. Try running your TV signal through a cable box or a old vcr using the audio out cables and video out cables to your tv input. if that works the problem is in the tuner section of the tv and will need to be repaired or replaced.
Posted on May 03, 2010
I have dvd tv combi and the sound will not go above 30. I have tried going into settings and the volume but nothing happens.
follow this steps and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 25, 2013 | Televison & Video
HELP! Dog stepped on remote and now volume on Sony KP53S65 won't work.
test this steps and fix it. God bless you
Jul 22, 2013 | Televison & Video
Volume too low on toshiba portable dvd sd-p91ske
see the causes and fix it:God bless you
Jul 21, 2012 | Televison & Video
I have a coby CSP96 speaker system. it said on the manual online that i found on the cobyusa.com site that there should be a volume control on top of the sub-woofer but there isn't one there. i can only...
I am having the same problem. I also have the combo dvd and theater system. I also read that the sub woofer is supposed to have a volume control on it but its not there. The only way to control volume is to connect to coby dvd player. This dvd player is beyond terrible. DVD looks bad and sound is miserable. I hooked up xbox 360 to my samsung 52 inch, then on the outputs of my tv into the inputs of the "TV" section on the Coby Sub woofer. At this point great sound quality comes from the xbox and all speakers, but the volume is uncontrollable and is blasting loud. Tv volume control does not work either. I am stuck like chuck and have not found a solution. This has to be one of the worse purchased i have ever made because i am forced to use a terrible DVD player just to get some sound through the speakers. I dont understand why on the speaker systems you buy without dvd combo has a volume control on subwoofer, but on the combo subwoofer doesnt have it. Just terrible. I will continue to look online and try and find a solution other than smash it to bits.
Oct 19, 2010 | Coby CSP-94 Speaker
Volume control works in DVD mode but not in TV
Where is your TV sound coming from? Is there a volume control at the source?
May 05, 2010 | Denon AVR-485 Receiver
Technics sa-dx940 tv volume control
Check the sound setting on your TV, is it Fixed level out, if so you have to turn volume up on TV to go through the receiver.
Mar 19, 2009 | Technics SA-DX940
Philips dvd player
Turn off the night mode on the Philips:
1 In ‘AUDIO SETUP’, press OK to enter
the submenu.
2 Press 3 4 to highlight {Night Mode}, then
press OK.
3 Press 34 to highlight one of the options
below:
ON
Select this to level out the volume. This
feature is only available for movies with
Dolby Digital mode.
OFF
Select this when you want to enjoy the
surround sound with its full dynamic
range.
4 Select an item and press OK.
Jul 20, 2008 | Philips DVD 622 DVD Player
Sony F Tinitron 36" Volume lower in regular TV mode, higher in dvd mode
Try to disconnect the dvd andvr when watching plain tv. Thi may help..
Cheers!
IrishDruid
Apr 26, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Dvd sound isn't working
In addition to the suggestion which I fully concur with, there is one small thing I would add. Kari you may not be aware that there is often an "internal setting" in the dvd player for its output volume. Sometimes the setting is inadvertently changed to a permanently "muted" or silent mode so that no audio can be heard. This internal setting is usually accessed by pressing the "Setup" button on your remote control and browsing through the main menus to the "Audio" or "Sound Setting" submenu. Once there you will see if the settings are correct in order to HEAR AUDIO (sound that is). Be sure to turn the "MUTE" to "off" and set the output volume to about 3/4 high setting. Then get out of setup mode and play your dvd. My point is this...on some "kareoke" feature units I have found many people mistake the front manual volume control for a DVD audio output level control when playing dvd's. This is not the case..the output volume settings are "internal" and accessible through the remote control only. Hope this helps Kari !- hattonhall
Sep 08, 2007 | RCA DRC8300N DVD Recorder/VCR
Dvd audio quieter than vcr audio
There may be an audio adjustment in the dvd player that wasenr set up at the factory correctly. depending on how old the unit is I would contact the manufacturer and see if its under the factory warranty as you DO NOT wanna go inside and start turning controls as this will or could throw the entire alighnment out of the dvd player. I(f theres no warrantee then you could ask them if theres an audio output adj and what the pot # was. Or else your gonna need to get a service manual and throw ya back a few bucks. But my guess is that if you bug the service guys enough they will tell you where the adjustment is. Good luck
Apr 22, 2006 | Emerson EWD2003 DVD Player/VCR
Insignia IS-LCDTV32 32 in. Television Logo
61 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
