Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Silverdragon posted on here about the Whirlpool Wtw6600sw2, cabrio giving me the F50 code on how to solve it,--F50 - motor stalled The biggest problem with this machine is the rps sensor. If you pull the motor cover you can get to the rps. Then take the rps on and off about 5 times to remove a factory coating that keeps it from making the contact that it needs. For some reason the machine will work fine for several months after purchase before this occurs. After you do this it works fine. F50 f51 f70. How do you take off the motor cover?
    Problem Solver:
  • 19 Answers
Tip mch back and locate the lg allen bolt in the center of the magnet and remove counterclokwise. The motor is actually a large magnet that revolve around a stator, a series of windings. Pull hard and place magnet away from any metal. Once off, remove the bolts holding the stator to the base and on the reverse side is the rps sensor. It looks like a wedge and is clipped onto the stator.
Posted on May 03, 2010
Whirlpool cabrio washer giving f50 error
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 28, 2013 | Washing Machines
Hello~ We've been struggling to repair our Whirlpool Cabrio washer - Model - WTW6600SW2. We received the codes F50, F72 and just F - we replaced the stator motor and RPS sensor kit; however, we are...
Hi
Please check this list of codes in whirlpool cabrio.You will get a detailed idea about code F 50 and the test to be performed:-
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Not spinning and showes error F 50
F50 = Motor Stall Error
The biggest problem with this machine is the rps sensor. If you pull the motor cover you can get to the rps. Then take the rps on and off about 5 times to remove a factory coating that keeps it from making the contact that it needs. For some reason the machine will work fine for several months after purchase before this occurs. After you do this it works fine. F50 f51 f70 codes
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio wtw6600sw2 f50 code.It spins freely.What now?
Any time you get a F-50 code on one of these, Whirlpool recomends you replace the control, wire harness, and RPS sensor if the tub bearing main shaft aren't binding.
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops and gives f50 code
Hi, the F50 error code is a stalled motor error. There is a part called a "Rotor Position Sensor" that sees the motor running. This error will display if it faulty..
Sep 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I need the service manual for a Whirlpool Cabrio WTW6600SW2 to find out what the code F50 mean and how to replace RPS sensor.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f 50 on cabrio WTW6600SW2 what is the most likley cause
Silverdragon posted the following yesterday about this issue...
http://www.fixya.com/support/t4267679-wtw6600sw2_cabrio_giving_me_f50_code
F50 - motor stalled The biggest problem with this machine is the rps sensor. If you pull the motor cover you can get to the rps. Then take the rps on and off about 5 times to remove a factory coating that keeps it from making the contact that it needs. For some reason the machine will work fine for several months after purchase before this occurs. After you do this it works fine. F50 f51 f70 codes
Mar 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600sw2, cabrio giving me the F50 code. Any ideas as to what that means?
Mar 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer keeps flashing code F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
493 people viewed this question
Dan Webster
Dan Webster
Sal De
