Question about American Standard 1480.104.002 SEVA Single Control Lavatory Faucet - Polish
What size allen wrench to remove seva flowise shower handle?
Merican Standard seva flowise shower faucet. what size allen wrench to remove handle? tight quarters and don't want to strip.
  • 2692 Answers
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool)  Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Posted on Feb 08, 2009
broii4x4
  • 13 Answers
SOURCE: Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: leak in the faucet handle
You'll need an allen or hexkey wrench of the apropriate sixe to remove the handle from the faucet. There should be a rubber plug with the traditional red and blue colors for hot and cold. Carefully pry the plug out. There should be a hex nut in behind the plug.Remove the hex nut and the handle should come off by pulling straight upward.After that the dome shaped nut that sits below the handle should turn off counter clockwise. Beneath this is where the seals, springs, and washers are located. Good luck
Posted on May 20, 2009
smartr10U
  • 1305 Answers
SOURCE: how to replace sprout seal kit?
After you remove the handle, the chrome cap should either snap or spin off.It also may come out with the cartridge... There are 3 screws that hold the cartidge in the faucet...take them out and you should be able carefully work the faucet are off of the core of the faucet. Put a little cooking oil on the o-rings after you install the new ones... just to allow the faucet arm to slide on without damage... Hope this gets you dripless!! Let me know if you have a question. K
Posted on Jun 05, 2009
  • 4 Answers
SOURCE: Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Posted on Jun 13, 2009
Removing on/off shower handle, use an allan wrench i know, but can't seem to see to screw thru the opening and determine size of wrench to use. any suggestions?
If you can not see the set screw with a light you will need to just try allan wrenches until you find the one that fits.
I know that's not what you want to hear but with all the different sizes out there and then add in the metric stuff it is impossible to now what size your working with.
I went to the american standard book and over the years they have used 9 different sizes some metric and some standard us.
Mar 02, 2011 | American Standard One Handle Shower Only...
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
We cannot get the handle off the tub/shower faucet
Look for a small little hole on the handle. I think you will need an Allen wrench that size that will turn the screw and remove the handle.
Dec 14, 2010 | Moen & One Handle Tub & Shower Faucet
I have an american standard bathroom faucet. Single handle. It is leaking where the faucet meets the sink. I do not see any screws to take off the handle. How do I fix it?
First, turn off the water supply under the sink. Next, put the faucet lever in the up position, no water should be coming out. While in the up position turn slowly while looking at the underside of the handle and you should be able to find a set screw. It will probable be an "allen head" type and you will need and allen head wrench to loosen it. An allen head looks like a hex shape, 6 sided I believe and is rod shaped. If you don't have one they come in sets at your local hardeware.
Jul 16, 2010 | American Standard - Lavatory Faucet -...
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Trying to disassemble Ladylux Cafe faucet. Grohe
If it is just replacing the handle you will only need a smaller screwdriver set (pretty common) and an allen wrench. I don't know exactly what size you need but you can get a set of these wrenches pretty cheap at any tool or hardware store. Basically the tool is a hexagonal rod that is bent in the shape of an "L". You'll need the smaller set for this job sold usually in sets that have a range of sizes from .05" to 3/8" diameter. I would guess your hex nut is 1/8" or less.
On the bottom of the handle between the sink bed and the handle you'll be able to feel a small hole. When you stick the allen wrench in there it should fit snuggly if the allen wrench wiggles a lot go to the next size up. Since the screw is facing up you will pull the other end of the wrench toward you. This will loosen the screw. It will not take a lot of effort so if you have to force it make sure the allen wrench is actually seated. Kind of a pain but you'll have to reposition the wrench as you get it loosened to fully extract the screw.
Once the screw is out the handle will drop down and the cap just pulls off. Assembly is reverse but make sure that your screw is going into the threads without resistance before tightening. This will prevent cross threading.
Feb 15, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
How to fix a dripping faucet?American Standard single lever handle.
Hello. These faucets use a replaceable cartridge valve and when they drip they're ready for replacement. Remove the handle by loosening a small screw ,usually with an allen wrench, and maybe another nut under it.The cartridge should pull out but mat be stubborn. Take the valve with you when you go shopping there are many variations.
builderdale
Jan 22, 2010 | American Standard - Lavatory Faucet -...
My handle is loose but I cannot find a tool that will fit the set screw. What is it, what size. Blade screw, Phillips Screw, Hex, torx, what? Moen T2442 single handle shower diverter.
It would be an allen wrench. Any typical multi sized wrench should have the proper sized allen wrench.
The holes can often become filled with grime so be sure to seat the wrench properly to prevent stripping.
Aug 07, 2009 | Moen & One Handle Tub & Shower Faucet
American Standard 1480.104.002 SEVA Single Control Lavatory Faucet - Polish Logo
227 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
