Question about Kenmore 62602 Electric Dryer
Dryer stayed on all night. The dryer works; however no heat. Timer stays in one position. I take it that the timer is bad?
  • 10,319 Answers
Yes you are correct
get a new timer
Posted on May 03, 2010
2 Suggested Answers
garing
  • 998 Answers
SOURCE: Mod: LGR5620KQ1 dryer keeps running. timer stays the same.
sounds like short to ground and feed back to timer
Posted on Aug 31, 2009
Admiral Dryer. 6.5 cu. ft. Electric Dryer in White AED4675YQ0 will not stop heating will not cool down AND IT SEAMS AS THO THE HEAT ELEMENT IS STILL ON WEN TIMER IS AT AN OFF POSITION
It sounds like the heat element is bad. It is touching its metal housing causing it to be grounded. It is supplied with 120 volts so it will stay on. You will need to replace the heat element. In the mean time unplug it or turn the breaker off.
Jun 04, 2018 | Admiral Dryers
Heat stays on while blower is off and burning fuze
If you mean that the dryer timer is at "OFF' and the heater coil continues to heat, then the timer contacts are "welded" together. Check/replace the timer.
If you mean the blower is not running during a drying cycle, the the various heat-sensors, including the thermal-fuse are doing their jobs. Find out why the blower is not working: Bad motor, blocked 4" duct, etc.
Oct 24, 2013 | Amana NED4600YQ Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Dryer runs but does not get hot
if timer runs thru cycles then it is the element sounds like timer
Oct 30, 2009 | Whirlpool LER8648P Electric Dryer
My dryer works ...tumbles ...heat works...timer stay where you put it when you start it..maytag dependable care plus dryer
Your timer motor is bad. It is very similar to a clock motor and it drives the timer on your dryer.
Oct 08, 2009 | Maytag Dryers
Aug 31, 2009 | Whirlpool Dryers
Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
Oct 29, 2007 | Dryers
Kenmore 62602 Electric Dryer Logo
108 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
