Question about Brother MFC-7820N Laser Printer
Cannot get printed faxes
I have on ephone line with adsl. the adsl is filtered off and the phone line is also my fax line. My multifunction is set to 4 rings before answering the Fax. When a fax comes in the phone rings then the MFC says "receiving" and after a while the message goes away but nothinh else happens.
  • 62 Answers
The phone line needs filtering off ,because your fax machine is an analoque device
Posted on May 11, 2008
Do i need a spechel line for a fax ore it can be a reguler phone line ?
A regular Analogue phone line.
Analogue ! Not a PABX phone line which is most likely Digital .
IF using ADSL you need an ADSL filter and need to put FAX line into Phone part of Filter.
Oct 11, 2015 | Office Equipment & Supplies
My M1255nf works fine except that since we moved last month, when I get ready to send a fax the line is very noisey even with the phone line removed. I tried replacing the fax card but still same noise. I...
Do you have ADSL internet in your new place? If so you will need an ADSL filter plugged into the phone outlet and plugged into your fax machine. so it would look like phone wall jack--->filter-->fax machine.
ADSL internet creates it own jabber or digital noise in the line and the filter will stop your a analog device from hearing the noise. If you don't have a filter for your phone as well, you should get one. Without filters your ADSL internet will be slower as well. Your ADSL modem should have came with at least 4 filters, if not they can be purchased at your local Bestbuy, staples or computer place. NOTE: Filters only work if you have ADSL or DSL internet.
If you do not have ADSL or DSL internet and still have noise you may have to call your phone service provider to get them to diagnose your line issues. They can fix some noise issues from their end.
Chris
Sep 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
May 20, 2010 | Brother MFC-7340 All-In-One Laser Printer
Fax is trying to answer my phone
Check the settings of your fax. You have to set it on which ring you wish it to answer. You can't fax without having a hard line phone plugged in. Also, you must have a filter on your fax line if you use DSL.
Oct 13, 2009 | Computers & Internet
My Epson bx300f cannot send faxes, just says no dial tone?!!!
ALL fax machines are ANALOG devices and will not work on a DIGITAL PHONE LINE.
Jul 06, 2009 | Epson Stylus Multifunction Printer/...
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Fax not clear
Noisy phone line can cause this or it could be drum cartridge or even fuser, check phone line for noise by listening to it, if noisy report it or put on required filter if using ADSL.
Also test machine when doing a copy, and when printing a report, is there a problem too?
without more info you fault is one of these.. line, drum cartridge , fuser or dirty scan glass (where originals are fed.)
Nov 08, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother mcf-440cn
Jacki
 Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
Oct 21, 2007 | Office Equipment & Supplies
Brother MFC-7820N Laser Printer Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
