Question about Bose & Wave& Music System
CD not playable
CD entered" - reading disk" flashes five times - "not playable" flashes ---"no disk" signal appears
    Scholar:
  • 70 Answers
Call bose for repair on this unit. The laser could be dirty but in most cases there is another failure. Possibly in the motor control circuit. They have a flat rate repair service.
Posted on May 03, 2010
How to reset security code
  • Select a five-digit number and record it in the manual or some place else easily accessible in case you forget it.
  • With an assigned fob present, turn the "IGN" key in this pattern:
    Ignition-Off-Ignition-Off-Ignition.
  • Press the left turn signal three times.
  • Press the right turn signal one time and release. The turn signal should flash three times. The current PIN number should appear in the odometer. The first digit will be flashing.
  • Enter the first number by pressing the left turn signal the same number of times as the digit. So if the first number is 5, press the left turn signal five times.
  • Press the right turn signal one time and release. The new number will replace the old number in the odometer.
  • Repeat steps 5 and 6 until all numbers have been reset.
  • Turn the ignition key to "Off."
DISARMING WITH YOUR PIN
  • Turn the key to "Ignition."
  • Hold both turn signal switches until you receive confirmation.
  • Press the right turn signal once.
  • Repeat steps 3 and 4 until you have entered your PIN.
Oct 11, 2013 | 2007 Harley Davidson XL 883 Sportster
CD player says reading disk about three times after a cd is put in and then the cd is ejected and the message says "not playable." we have tried to clean the head, but it also ejects the...
You can try clean the optical lens by removing Bose top cover ( make sure power off your device before remove the cover). Now instead of using cleaning disk, you can using cotton **** with cleaning lens liquid. Wipe clean the lens ( 2-3 times). After it gets dried, you can try your device. If still no joy, your optical lens is defective and need replacement.
Regards,
Sep 06, 2011 | Bose Wave Radio
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
How do i restore my hp pavilion dv 5000 to factort setting?
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process.
If there is no disk or got lost,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls response with your rate and testimonials below for further issues..thanks
Feb 23, 2011 | Computers & Internet
"No Disk" message
Your dvd lense need cleaning .
For that buy lense cleaner disk from nearest computer shop then put that disk into cd/dvd rom then play it then it clean dust from lense then you can use it again .
But if still same issue then you need to replace your dvd lense .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 24, 2010 | Sony Bravia DAV-HDX265 Theater System
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
CD player says CD (and I've tried a few) is not playable
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 02, 2009 | Bose & Wave& Music System
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Bose & Wave& Music System Logo
487 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
