Question about RCA Video Cameras
RCA CC6363 STEADY PIX AUTO SHOT 200X DIG ZOOM 2.5 LCD problems?
I have an RCA CC6363 STEADY PIX AUTO SHOT 200X DIG ZOOM 2.5 LCD Camcorder and its pretty old, but its always worked and all of a sudden when I turn it on it says ''E04 UNIT IN SAFEGUARD MODE, REMOVE AND REATTATCH BATTERY'' and no matter how many times I reattatch the battery, the same message comes up. I also appologize because I don't even know if this is the right website to be asking this!
SOURCE: Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Posted on Mar 21, 2007
eagle338
  • 4889 Answers
SOURCE: E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Posted on Oct 18, 2007
SOURCE: Shows fault E04 remove & reattach battery
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Posted on Apr 06, 2009
  • 4 Answers
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Posted on Dec 17, 2009
SOURCE: JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Posted on Aug 20, 2010
Where can I load a owners manual from
Hi; You can find almost any Service or Owner's Manual you want at: Service Manuals.net. I just got the Service Manual for my RCA CC311 camcoder from them. The cost was $17.00 for a PDF download (they offer other options). Please pass this Info. on to others.
Feb 23, 2014 | RCA 200x Digital Zoom Auto Shot Camcorder...
How do I charge the battery and how long does it last ?
Usually you just put it into the charger that should have come with your camera. If your Camera has an automatic charge feature built-in (you'll have to plug it into a wall outlet via the supplied adapter), and your battery is still dead... buy a new battery! They don't cost much! Batteries are generally good for approx. two-three years depending on how long you use your camera, and how many times they have been recharged! Newer Batteries are constructed better and can be recharged many more times before they need to be replaced.
RCA camcorder model # CC6363 is stuck in safe mode and I can't eject my tape, how do I solve this?
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=RCA+camcorder+model+%23+CC6363+is+stuck+in+safe+mode+fix
Hi at the above link, you will find a myriad of people with a problem exactly the same as yours, it is a real headache, with NO real, well DIY fix, sorry, it appears that RCA will repair it for a price, so maybe it would be simply best to bite the bullet, and take it to a professional RCA servicing center, but ONLY ask for a "Quote". Now when you get this information, then you can make up your mind as to what to do, repair or replace?
As an aside here, and it is mentioned in that link i give you above, that this problem is a "Known About Issue" and in some countries they have been made to repair this issue FREE of charge to customers...
I actually haven't come across this exact type of problem with this exact type of camcorder, however, in my shop, I have seen similar repairs etc, and they can cost upwards of $200.00, so make sure you always get that quote. Further, there are a few postulated "Fixes" in that site given too, you can not do any real harm in trying any or all of them, especially the one about cleaning the "Heads & tape transport path" as described, this may just work, as may the Battery Removal/Replacement ... so good luck.
Jun 27, 2011 | RCA CC6373 Camcorder
CAN YOU DOWNLOAD TO A COMPUTER FROM THE RCA CC6363 CAMCORDER. THANKS
Hello :
Yes you can . You need to download the driver for your Camera first .
PLEASE DON'T FORGET TO RATE .
good luck .
Apr 09, 2010 | RCA CC6363 Camcorder
RCA CC9360 Steady Pix camcorder has grinding sound, jerky playbac
I am sorry to say that it appears you may have answered your own question, the "hundreds of hours" is the clue.
Consider the possibility that your camera is worn out.
Sorry.
Dec 12, 2017 | RCA Video Cameras
Need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Oct 29, 2008 | RCA CC6263 Camcorder
Video Cameras Logo
473 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
