Question about Nintendo Super NES Console
How to hookup a super nintendo to a tv using a rf modulator
  • vivimage2000 Jul 03, 2010
    Do you have an RF Adapter or an A/V Cord?
    Problem Solver:
  • 13 Answers
Put the plug in side to the super nintendo and the screw in or push in, depending on which brand you have, to the back of the t.v. Now see what channel it is set to and use the same channel for the t.v. Voila!
Posted on Jul 12, 2010
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
How to install software to gfive g111 mobile
Computer Monitors
Nintendo home consoles are designed for use through home televisions and VCRs, using standard A/V, S-Video, component, or RF connectors (for older systems). Computer monitors typically do not have these connections. There are however two ways a hookup to a computer monitor could be accomplished:
With a PC TV Card:
A TV card inserted into your PC may allow you to connect your system if the card has the proper connections (such as RF, A/V, S-Video, component, or Coaxial). However, we have found that the image quality is not as clear as it is on a TV, in most cases.
With a Direct Connection (RGB or DVI Cables):
Nintendo does not manufacture any cables to make an RGB or DVI connection. While other companies may manufacture wires that can make this possible, we are not able to recommend them, as they are not licensed by Nintendo.
May 19, 2012 | Nintendo Super NES Console
HOW DO I HOOK UP MY SUPER NINTENDO TO A TV THAT DOESN'T HAVE AUDIO/VIDEO HOOK UPS?
You need an RF modulator or a modulator and a A/V switch (to avoid Daisy-chaining the game system to the DVD/VCR). These are available at many electronics shops (Radio Shack, etc.)
Here is one RF modulator: http://www.radioshack.com/product/index.jsp?productId=2103095 . There are many more out there; however, these days some stores may only have them in their online inventory.
I hope this helps.
May 13, 2012 | Nintendo Super NES Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Turn on the TV and set it to the appropriate channel (3 or 4.)
Nov 25, 2011 | Nintendo Super NES Console
We have no manual - need instructions on how to hook it to the TV.
Nintendo 64 Hookups
Quick Tip! If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
The Stereo Audio/Video Cable that is included with the Nintendo 64 will allow you to connect the Control Deck to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have Audio/Video inputs . Though your TV may not have them, almost all VCRs do.
If you DO have AV inputs, choose where you want to connect to:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
If you do NOT have AV inputs, you will need to use an RF Switch and RF Modulator for your hookup. The RF Switch and Modulator are sold separately. (Where to buy):
Connecting the RF Switch to a TV
Connecting the RF Switch to a VCR
Other Hookups
Feb 24, 2011 | Nintendo 64 Console
My super nintendo has no sound and I replaced the sound module and still no sound please help !!
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Check your system connections to ensure they are firm and correct.
Remove and reload the Game Pak, pressing firmly to ensure it is locked in place.
Many Game Paks have an option that controls one or more volume variables. These may have been set to maximum volume during the manufacturing or testing process. Consult the game manual for directions on how to adjust the settings. You can usually get to them by going into the Options screen.
Remove the AV cables and reinsert them with a slight twisting motion. Make sure the Video Cable (the yellow plug) is in the video input. Plugging it into an audio input will cause buzzing. Also, make sure none of your audio (red) cables, are plugged into a phono jack on your stereo, which can also cause buzzing. Finally, make sure the Stereo AV Cable is plugged into input ports, not output ports. For a detailed review of the hookup, please check our hookup instructions.
Some TVs or VCRs may have special Audio Inputs that don't allow the volume to be controlled by the TV. They are intended to be controlled by a different device, such as a home theater amplifier. Check your manual for the TV or VCR to see if this is the case for your unit.
Some TV and VCRs have a small switch, usually found near the AV inputs, that is used to allow components to send sound out to the TV speakers. Check your manual for the TV or VCR to see if this is the case for your unit.
If you are using the Stereo AV cable for your hookup, remove the plugs and reinsert them with a slight twisting motion. Make sure that you are plugging the yellow cable into the video input, and that the audio cables (red and/or white) are plugged into the audio input jacks on your TV or VCR.
If you only have one audio input, and one plug is hanging, that will result in a loss of sound. Either purchase a Y-adapter or access the game's option menu, and when available, set the game sound option to Mono.
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
Click here if the troubleshooting doesn't help
RF Hookups
Try switching both the TV and RF Modulator to a different channel (3 or 4). Try adjusting the Fine Tuning control on your TV to see if it clears up the sound. A particularly strong TV station (or cable TV) signal may be broadcasting on Channel 3 or 4 in the area, causing interference. For a detailed review of the hookup, please check our hookup instructions.
Try disconnecting the antenna/cable wire from the RF Switch. (You will have to reconnect it again for regular TV viewing.) If this option works, an AB Box may be needed. These can be purchased at various home electronic stores.
Dec 03, 2010 | Nintendo Super NES Console
How do I plug in the super nintendo to my computer? I don't know which cable goes into the "out" place.
Computer Monitors
With a PC TV Card:
Oct 26, 2010 | Nintendo Super NES Console
HOOKUP A MAGNAVOX DVD/VCR PLAYER TO TV AND DISHNET WORK CA
may be your tv systems don't have an accessory for audio video input. but you can hookup that by using an RF modulator adapter, this is a converter from audio / video to RF signal and connected directly to your antenna connection. you can purchase that RF modulator adapter to an electronics store.
Apr 18, 2010 | Sylvania SRT2319 TV
Snes screen jumps on certain tv
Okay, what I would try is hooking up the snes using the n64 cable. right next to the rf slot in the back of the super nintendo is a slot thats the same video output as the n64 you can plug in the rca cables from it and see if they work
Feb 27, 2009 | Nintendo Super NES Console
Nintendo Super NES Console Logo
138 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
