Question about Epiphone Eb0 Gig Rig Bass Player Pack Ebony
Setting string height on epiphone eb3 - Epiphone Eb0 Gig Rig Bass Player Pack Ebony
3 Suggested Answers
  • 161 Answers
SOURCE: which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
Posted on Mar 23, 2009
  • 1137 Answers
SOURCE: Epiphone Sheaton II guitar setup
This will help for starters:http://www.epiphone.com/images/EpiOwnrsManul.pdf This site has good info in the discussion:http://www.thefret.net/showthread.php?t=4728 There's info here too:http://epi.p3net.net/bbs/index.php.
Posted on Aug 11, 2009
Cant get the buzz out of the high E string on my Epiphone les paul guitar
A buzz on one string is not due to a pickup fault. It's rather a too low string height at the nut or a string slot that is either too wide or has too deep of an angle towards the tuner. It could however be that you had the pickup too close to the high E string creating excessive string pull.
Jul 04, 2012 | Epiphone Les Paul Studio Electric Guitar
How to change the strings onthe epiphone professional deluxe mandolin
You can slide the silver plate straight back by gently pushing it from the top with your fingers. Once it slides off you will then be able to see the hooks that you put the new strings on (loop end strings). Once strings are tightened, you slide the cover back on the same way you slid it off. There is a small piece of felt glued to the cover. Be careful not to knock it loose when you are putting the cover on.
One other tip, change one string at a time instead of pulling all of them off at once. The bridge will come loose if you take all the strings off at once (it is not glued to the mandolin).
Feb 17, 2012 | Epiphone MM-50E Professional Mandolin
No sound on high e string
Have a look at this link:http://www.lespaulforum.com/forum/showthread.php?p=1490000 A dead pickup would not affect just one string so it has to be an adjustment problem. Here is another link:http://www.mylespaul.com/forums/custom-shop/1910-pickup-adjustment-height-pole-pieces-comments-discussion.html
Oct 28, 2010 | Epiphone Les Paul 100 Electric Guitar
What is the recommended height for humbucking pickups on a epiphone lp 100?
the closer to the strings the greater the magnetic pull. it's a personal variable to the player.basically how aggresive of a sound you want
Dec 30, 2009 | Epiphone Les Paul 100 Electric Guitar
What should be the height of the pickups on my sheraton 2?
Pickup height on electric guitars is an oft debated subject. It's more about personal preference, ..BUT there is a bit of science involved , and here is some real simple "String Theory" for electric guitars. Your pickups are magnets essentially, with little winds of copper wire - this is how a transducer (pickup) picks..up (hence PICKUP) the sound of the strings. Strings are steel , most brands have Steel wrap around a Nickle core, ..it is ALL attracted to magnetics. You've played with magnets before , right? What happens when you put a magnet close to metal? It...PULLS it , right? Now , here's the deal about THAT , for guitars. The closer you get a vibrating string to the pickups , the more signal the string will produce , BUT if you get TOO close, the pickup will start pulling on the string too much (remember..magnetics) and that will reduce the amount of sustain on a string(s), and may even hamper actual tuning depending how strong the pickups are. Of course there is the "Duh" factor - having your pickups so high that your strings actually rub them as you play , ...don't do THAT! Best advice: Keep the pickups about mid-way. Not high enough to cause any noticeable problems, but not too low to sink them below the pickup rings (the plastic rectangulars that surround the pickups.
Nov 02, 2009 | Epiphone Elitist Sheraton Electric Guitar
Truss rods and dead frets- how do I adjust the guitar so the strings are close to the neck without getting dead frets?
I own an Epiphone Casino and if I needed to adjust the truss rod I would take it to a luthier (stinged instrument repair person). There is a good write up on it here. http://www.fretnotguitarrepair.com/trussrods.htm
Hope this helps.
Bob
Oct 31, 2009 | Epiphone Les Paul 100 Electric Guitar
Which string used for epiphone gibson lea paul special II guitar
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
Strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Nov 15, 2008 | Epiphone Aj-100 Acoustic Guitar
Problem with the pickup sound on the 'g' string on my epiphone les paul standard
Hi ! Must be a problem with either the nut or the g-saddle in the bridge of the guitar.
Good luck , Stefan from Sweden
Nov 10, 2008 | Epiphone Music
Epiphone Eb0 Gig Rig Bass Player Pack Ebony Logo
377 people viewed this question
Top Epiphone Music Experts
Robert Graf
Vito Vacirca Jr.
dave nyman
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
