Question about Canon PIXMA MP130 All-In-One InkJet Printer
Have a Pixma MP130 multifunction printer copier giving me the warning that my "waste ink absorber is almost full, see manual" Trouble with that is, the manual I have does not have an item like that. I look with my flashlight into the inside, and to the far right I think that might be it.... how would I proceed to fix this problem? Please?
  • girishgka Apr 12, 2008
    have a Pixma MP130 multifunction printer copier giving me the warning 'waste ink absorber is almost full, see manual'. The Trouble is that the manual does not have an item like that. Please help.
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu.
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit.......Done
I hope this help!
Posted on Jan 15, 2015
    Genius:
  • 3,587 Answers
Do you have a manual on this printer?
also, see this for more assistance
Posted on Apr 25, 2008
SOURCE:
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste Ink absorber is full.
this msg show that you will need to reset your printer waste ink counter and replace the waste ink pad.. you can try to reset it with a resetter software here.
http://www.fix-printer.moon4ever.com/?cat=5
May 28, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste Ink Absorber on Pixma MP130 multifunctional is almost full.
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full How do i empty it
You can't empty that one, you need a shop to replace the pads which are under the printer, and they can reset the waste ink counter at the same time.
Sep 29, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink asborber i almost full... how do I fix
I am providing you with a link that will provide you with everything you could possibly need as the owner of this printer. This link on Canon's Web site will give you access to user guides/manual, driver and software downloads, support, specs for the system and much, much more.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442
This link will take you directly to the Support & Service tab on the Canon Pixma MP130 page.
(If not, simply click the tab labeled Support & Service).
Type "waste ink absorber" in the text box then click Search.
Click 1. ERROR LCD: WASTE INK NEAR FULL which will result in 4 solutions to this problem:
  • Ink absorber replacement options - mp130
  • Press ON/OFF switch to reset the multifunction device
  • The mp130 may require repair
Try 1 and 2 first. You must click on the solution to view the details.
This should also be helpful in the future event that you may need to download drivers or access the manual to troubleshoot/fix an issue. Drivers and Guides can be downloaded from the Drivers & Software tab.
Hope this helps! Share your experience by rating this solution.
Thanks for using Fixya!
Mar 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is full, waste ink full, waste ink absorber, abs, ink absorber full
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-5
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
52 people viewed this question
Clive
Clive
old marine
old marine
Ekse
