Question about Kenmore 64942 Electric Dryer
I have a Kenmore electric drier # 110.60912990 It runs fine, but no hot air. What should I check. I checked the outside vent and air is coming out. I check the circut breaker and it is fine.
  • Kenmore Master
  • 43,501 Answers
If you have a gas dryerI have a Kenmore electric drier # 110.60912990 It - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
I have a Kenmore electric drier # 110.60912990 It - 2_bing.gifr Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
Dryer will heat up then shut off
Most likely it's getting to hot, check your vent and the outside vent hood make sure you have proper air flow. Turn on the dryer check the vent exit to make sure you feel hot air coming out. Take the vent off and check the back of the dryer for air flow. If you have air flow and the unit is still over heating you may need to replace the operating Thermostat. Could tell you more with a good model number should be inside the door.
Oct 26, 2013 | Kenmore 62602 Electric Dryer
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Dryer is hot and running the clothes don't get dry
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 01, 2011 | Dryers
I have a front load Kenmore dryer HE2 that seems to be getting very hot...only in the inside. You can really feel it more than normal when you open up the door
Your exhaust is plugged. Start your dryer go outside to the vent and feel for air coming out. If no air or just a little is coming out, check your exhaust tubing. Make sure you check the outside vent.
May 30, 2011 | Kenmore Dryers
Doesnt dry very well. takes about two days for clothes to dry completely.
If your drier is getting warm. You need to check the vent hose and the vent to the outside for a restriction. If the vent hose is stopped up, she will not dry proper, the hot moist air can not get out of the drum and just keeps it all inside. Now if is not getting hot, you have an electrical problem with the heater coils, that may take a tech. to come out and fix for you. Hope this helps Fix ya up.
Apr 26, 2011 | Dryers
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
My dryer runs and gets hot but takes 2 or 3 cycles to dry .
Please check your exhaust line fron the lint filter to the outside vent. When I say check, what I mean is take the machine away from the wall remove the hose and vaccum out the drier outlet --- use the crevice tool. When you are done with this, put a nylon over the end of the outlet and turn the drier on. You should have a good amount of air coming out. There will probably be lint - the reason for the nylon is to catch it. If not - do it again. (use the air setting) ... do the same with the hose. If you have access to the other end, disconnect it as well .. check that the door on your outside vent is not stuck shut. If you have a plastic hose, please replace it with a flexible metal hose.
I hope this helps you
a
Oct 02, 2009 | GE DBXR463EBWW Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
Kenmore 64942 Electric Dryer Logo
137 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
